Reverse problems
Old 07-03-2009, 12:26 AM   #1
markkearns's Avatar
markkearns is currently offline
My Model: 1994 241 Davanti
Send markkearns:
Default Reverse problems
1994 241 Dav.
I am having trouble getting the controler into reverse. I can get it there but it requires a lot of effort.
I have had the orginal controler replaced. The cables replaced. It improved a lot on the foward motion but still tight in reverse.
I had the mech open up the stern drive and it looks like thats where the issue is but I am not sure what the cause is and dont know what the next step should be.
The case had no water in there and I could not see any corrosion on the gearing. The cotter pin was tight, but even when it was taken out it did not make a lot of differnece.
Just looking for any ideas.
  • Old 07-08-2009, 04:09 PM   #2
    AirNavy's Avatar
    AirNavy is currently offline
    My Model: Z215 Talari
    My Engine: 5.7L Alpha One
    Send AirNavy:
    Default Re: Reverse problems
    Sounds like the problem lies between the shift shaft, shift spool, shift crank or the reverse gear. Take a look in section 3B of the sterndrive manual.
    Mickey
    AEC (AW) U.S. Navy
    Wakeboard Problems 300sflyer Watersports 5 08-19-2010 04:39 AM
    planeing problems boat man2 Original Mariah Talk 5 06-05-2009 02:20 AM
    3.0L engine problems pimpadelic Mercury MerCruiser 7 05-16-2009 08:26 AM
    Steering problems joshandsony Original Mariah Talk 2 07-22-2008 06:59 PM
    Radio problems giterdnn Original Mariah Talk 2 04-28-2008 05:29 PM
    There are 401 users
