Horn Design/Mounting problem
Old 03-23-2012, 09:04 PM   #1
DFZ272 is currently offline
My Model: Z272 Barchetta
My Engine: 7.4 Bravo III
Send DFZ272:
Default Horn Design/Mounting problem
I hope this information is helpful to others. My Z272 had(I removed them) hidden trumpet horns behind a grill on the starboard side. The problem was that the way the horns were installed they would fill up with water when the boat was washed or I got caught in the rain. I found this because the horns started sounding terrible. When I pulled them out I poured a few ounces of water out of each. Besides damaging the horns, this is a potential way for water to get into you boat where it is not suppossed to be. Anyway I removed the horns, put a block off plated behind the grill, and sealed it, then added a surface mount horn, the original electric horns were not available anyway. So no more water inside the side wall of my boat. The only way to access the horn area is to take off a couple of inside panels.
Happy Boating
Dan
1995 Z272 Barchetta
Thank you DFZ272 for this useful post!
mikeyt (03-24-2012)
    Mounting a GPS Plotter 300sflyer Original Mariah Talk 10 07-01-2019 05:56 PM
    Transducer mounting question nglauer Original Mariah Talk 0 07-16-2011 06:19 PM
    Subwoofer mounting question 1999Mariah Original Mariah Talk 4 08-05-2009 02:30 PM
    Bimini Top Mounting ewcjoro Original Mariah Talk 3 08-03-2008 11:53 PM
    Barchetta Hull Design boarder1010 Original Mariah Talk 8 07-08-2008 06:20 PM
    There are 366 users
