out drive
Old 03-22-2012, 02:19 PM   #1
mikstick is currently offline
My Year: 2003
My Model: sx9
My Engine: 4.3 mercury
Send mikstick:
Default out drive
last summer i bought my first boat.its a 2003 sx19 with a 4.3 mercury engine.i have noticed that when i take off the rear of the boat sinks real low in the water,till i pick up some speed.what position should the out drive be in when u start.i just watch a video on this web site of a 2006 sx19 and the boat seem to be level from start to finish.that boat had a 3.0 engine.the driver on the video was seated from the start.i would never see the water if i satdown when i start off in my boat.
  • Old 03-22-2012, 03:54 PM   #2
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Default Re: out drive
    The outdrive should be completely down as far as possible when starting and when you reach a planing speed, you can then begin to trim it up to reach optimum performance. There are other contributing factors to how fast she will plane, like prop size and condition and some other things that will effect your performance too.
    Zack
    1994 Z212 Shabah
    Thank you Zackattack for this useful post!
    mikstick (03-22-2012)
    Old 03-22-2012, 05:46 PM   #3
    Zack's right on with his advice. Let us know what prop is on your boat too. The usual prop is a 14.25" x 19" 3 blade aluminum. If you have something with more pitch (like a 21" or higher) then that may cause it to bog down at the start.
    While your here.......do a site search for "Smart Tabs". You will find numerous threads discussing their benefits. They will make a world of difference in your planing ability.
    Old 03-22-2012, 06:16 PM   #4
    My Year: 2003
    My Model: sx9
    Send mikstick:
    thanks for your help.my boat right now is having gimbel bearing change.i will check out the prop when there done.
    drive problems candanewell Boating 101 6 06-01-2010 02:41 AM
    drive and leak berk1402 Boating 101 1 05-20-2010 03:10 AM
    Drive lube oil Brian Boating 101 15 08-10-2009 12:19 AM
    Greasing Drive jakejorgenson General Maintenance 0 02-03-2009 03:40 AM
    need new bravo three drive luv2boat Mercury MerCruiser 6 08-30-2008 09:54 AM
    There are 264 users
