electrical problem
Old 03-09-2012, 03:20 PM   #1
breakaway is currently offline
My Model: Shabah 218
My Engine: 5.0 Bravo III
Send breakaway:
Default electrical problem
I have a 1999 Mariah 21 foot boat, merc v8 with bravo 3. I do not have an owners manual so a little help is asked for. The alternator stopped working but tests just fine. The electric choke does not energize. I am thinking the 2 are related as part of the starting circuit/trigger to start the alternator and that there is a common point here somewhere??? any suggestions would be appreciated
  • Old 03-09-2012, 06:15 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: electrical problem
    If you have had the alternator checked out then it sounds like you have a wiring issue on the boat. First check for broken or disconnected wires. Assuming no one has rewired the boat you should still have the std Merc. colors. You should have a fat orange output wire and skinnier black (ground), purple (excitation) and red/purple (voltage sense) wires.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 03-09-2012, 06:43 PM   #3
    Send breakaway:
    thanks, yes those wires are correct so will get to the wires and or a common fuse perhaps
    Old 03-09-2012, 07:58 PM   #4
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    Also, check your grounds. 12Vdc will do some funny stuff when it doesn't have a good ground. Water causes corrosion, and corrosion causes bad connections.
    Electrical problem Talari95 Original Mariah Talk 1 09-12-2011 03:27 AM
    Intermittent Electrical Problem jwpilger General Maintenance 13 08-13-2009 02:44 AM
    Electrical Problem with Gauges Douglas Alderman Original Mariah Talk 4 07-15-2009 05:36 PM
    electrical problem nickc Sea Fox - Mariah Talk 4 02-24-2008 06:34 PM
    There are 333 users
