electrical problem
Sea Fox - Mariah Talk
Old 02-06-2008, 07:27 PM   #1
nickc is currently offline
Send nickc:
Default electrical problem
Has anyone got a wiring diagram for a 2006 sx18. Or know what the following problem could be.
My boat wont start, It seems to be an electrical problem, With only half the dash getting electric, The trim adjusts, stereo and lights go on however the buzzer does not sound and turning the ignition key does nothing.
Anyone have any clue as to what the problem could be? The battery must be okay as i charged it full and then on jump leads again.
Thanks.
Nick
  • Old 02-06-2008, 08:39 PM   #2
    Hi Nick,
    Diagnosing electrical problems can be a very time consuming task, it may be more prudent to take your SX18 to a qualified service shop.
    In the mean time, here are a few quick things to look at....
    • Have you checked your fuses and/or circuit breakers?
    • Is your kill switch lanyard installed?
    • Have you checked under your dash and engine bay for signs of any wiring having come loose?
    • Have you checked the reset breaker on you motor?
    Good luck and let us know what you find,
    Old 02-06-2008, 08:49 PM   #3
    and add 'did you check to see that all of the wiring is still attached to the battery posts'? Those smaller wires have a habit of working loose occasionally.
    Old 02-21-2008, 07:06 PM   #4
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    I had a similar problem, I had full electrics but the motor just didnt want to turn over. It clicked like the starter didnt want to work. You know just like in your car when you have full battery power but the motor wont crank.
    Well I fiddled with the Throttle a little bit, just moved it back and fowards, and "dah dah" she fired into life no problemo.
    Give it a go, it might just be the same thing.
    I will post you 2 cents later.
    Tony
    Perth, Western Australia
    Old 02-24-2008, 06:34 PM   #5
    97 Z222's Avatar
    97 Z222 is currently offline
    My Model: 97 Z222 Shabah,7.4L carb, Bravo I 21p stainless 3 blade prop
    Send 97 Z222:
    Did you check the deadman switch? Easy to overlook we always think the worst when it won't start.
    Wanted: Electrical Wire Diagram (99 Jubilee) 214 Douglas Alderman Mariah Parts For Sale & Wanted 3 04-13-2008 05:22 AM
    Marine ACDC electrical site mikeyt General Maintenance 0 03-05-2008 12:37 AM
    Name this Problem ShabahZ280 Original Mariah Talk 5 10-09-2007 01:41 PM
    Electrical Fix Straad General Maintenance 2 08-28-2007 12:26 AM
    There are 333 users
