Original depth gauge transducer
Old 02-10-2012, 09:34 PM   #1
Purple_Shabah's Avatar
Purple_Shabah is currently offline
My Model: Shabah 182
My Engine: 4.3 Apha
Gallery Images: 19
Send Purple_Shabah:
Default Original depth gauge transducer
My in dash depth gauge hardly worked last summer in water less then 6 feet deep. I did find out the transducer (hockey puck) came loose from the floor. So I'm going to try to epoxy it back down this spring, hopefully that will fix the problem tho I've heard it's kind of hit and miss getting it to work again.
My question is, does Lowance make a transom mount transducer that will work on the original in dash gauge in case I need a plan B?
Time flies when you're having rum.
  • Old 02-10-2012, 11:25 PM   #2
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Default Re: Original depth gauge transducer
    For whatever it may be worth, to me it seems like most the members here that have re-epoxied theirs have had good luck. Just be sure to use slow cure epoxy so there won't be any air bubbles.
    Good luck. I'm curious to see the responses about your question.
    Depth gauge transducer asclarch Original Mariah Talk 7 07-08-2011 02:02 AM
    another depth gauge transducer problem Dutch180SE Original Mariah Talk 12 08-06-2010 12:22 PM
    Faria depth gauge Slamsanders Original Mariah Talk 7 08-05-2010 11:04 AM
    Depth Guage transducer stanciep Original Mariah Talk 2 07-17-2010 11:28 AM
    Aftermarket Depth Gauge Kitto Original Mariah Talk 16 07-13-2010 02:02 PM
    There are 266 users
