Hard starting 5.7L
Old 09-26-2011, 03:55 AM   #1
My 210 Talari is currently offline
My Model: 210 Talari
My Engine: 5.7 mercruiser ,Apha 1
Send My 210 Talari:
Default Hard starting 5.7L
I have a 1994 Talari 210, 5.7lL. Hard to start. Last time out it appeared to be flooding and had to open butterfly plates to light. Changed the plugs, cap and rotor since they were the orginals. Still hard to fire. Any thoughts??
  • Old 09-26-2011, 05:54 PM   #2
    voodoo's Avatar
    voodoo is currently offline
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    Default Re: Hard starting 5.7L
    Does it start fine cold, yet if you shut it down and try to restart a short time later you need to override the shifter and open the throttle to start it?
    That was my problem.
    Replacing the choke thermostat helped alot.
    Old 09-26-2011, 06:18 PM   #3
    Send My 210 Talari:
    Opposite, Hard to start cold. After it runs i can stop and start without problem. I heard those Choke Stat units pricey
    Old 09-26-2011, 07:25 PM   #4
    voodoo's Avatar
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    Do you cold pump it a couple of times to set the choke and pump some raw fuel in?
    Old 09-26-2011, 09:11 PM   #5
    jgreen's Avatar
    jgreen is currently offline
    Gallery Images: 2
    Send jgreen:
    Check your timing.
    Jay
    Old 09-27-2011, 02:58 AM   #6
    Send My 210 Talari:
    Do you cold pump it a couple of times to set the choke and pump some raw fuel in.....
    No last boat was fuel injected. I guess I have to get used to this carb. It Started fine 1st 4-5 times I took it out. Just lately it started acting up so did the tune up.
    Old 09-27-2011, 05:52 AM   #7
    drhate's Avatar
    drhate is currently offline
    My Model: shabah z 212
    My Engine: 5.7L magnum alpha one
    Gallery Images: 2
    Send drhate:
    I'm assuming you have the thunder bolt IV ignition. My guess it's the ignition sensor. It is located in the distibuter. Has 2 or 3 wires (depending how old the part is) coming out of it. Mine did the same thing for a while before it quit starting all together. It would fire up easy cold and out of the water but would crank and crank forever when it was cold and sitting in the water. After she warmed up it started up easier but like I said, the problem got worse. I replaced the sensor but not till I went through a full tune up, new coil, fuel/water seperator, new kill switch, battery, checked timing, fuel lines, check for bad gas ect. Couldn't find the gremlin till it stopped starting because I would always have spark at the spark plug but it must not be a strong enough spark when it starts cold. Part cost $50 and very easy to replace, unless the rotor is glued on. Which mercruiser usually did but looks like you changed the rotor already. Good luck
    Thank you drhate for this useful post!
    My 210 Talari (09-27-2011)
    Old 09-27-2011, 11:29 PM   #8
    Send My 210 Talari:
    Thanks. I will get part and install asap
    Old 09-28-2011, 08:29 PM   #9
    domraga's Avatar
    domraga is currently offline
    My Model: 218
    My Engine: Volvo 5.7GL / SX-M
    Gallery Images: 32
    Send domraga:
    If you are playing about with the dizzy, don't forget the timing. If you forget the timing, you could have fixed the original problem and reintroduced a new one. Also remember to mark up the dizzy if you remove, at least it helps get it the right way around. If you are 180 degrees out, you will be trying to ignite on the exhaust stroke and it will never start!
    Old 09-29-2011, 03:21 AM   #10
    Send My 210 Talari:
    no yank the dist. Buying the control module and installing. I have learned from muscle car v8"s to keep dist in place
    Hard starting 4.3LX mx20 Original Mariah Talk 3 10-06-2011 11:09 AM
    Hard Starting Once in Water julrich_32 Mercury MerCruiser 2 09-07-2011 03:06 AM
    Hard Steering Kirkyer Introductions 0 07-19-2009 12:53 PM
    hard steering duketter Original Mariah Talk 2 06-07-2009 02:47 PM
    Hard steering Jimh23 Original Mariah Talk 4 06-05-2009 10:52 AM
    There are 336 users
