Hard steering
Old 06-04-2009, 02:30 AM   #1
Jimh23 is currently offline
My Model: 180 Diablo
My Engine: 3.0L Alpha I
Gallery Images: 4
Send Jimh23:
Default Hard steering
On my 1993 180 Diablo with 3.0 liter engine, I find it difficult to turn to the right in the 30 mph and higher speeds. Turning left is no problem. I do not have power steering. Any thoughts?
  • Old 06-04-2009, 07:01 AM   #2
    Default Re: Hard steering
    Hi Jimh23,
    On many of the out drives there is a small metal fin sticking downward behind the prop. This is called a trim tab and it is used to off-set the torque of the propeller at cruising speeds by acting like a small rudder. The trim tab is also a sacrificial anode, so over time, it will corrode away, requiring replacement.
    As a contributing member, you would have access to our growing library of manuals, brochures, wiring diagrams, and all sorts of information relevant to your Mariah, the stern drives and equipment. Here, you would find the proceedure for the trim tab adjusment. See as you're new to the club, I'll explain the procedure but please consider becoming a donor, it's the second best investment for keeping your Mariah in top condition, joining the club was your first!
    Let's begin -
    With the engine OFF and the boat at rest, remove the small plastic plug (blue arrow) from the top of the drive shaft housing and loosen the Trim Tab bolt (you will need an allen wrench for this).
    Since steering to the left is easy, you will be adjusting the Trim Tab (circled in red) so the trailing edge is facing to the right when viewed from the rear of the boat. Make small adjustments and test the boat at cruise speed each time. It will probably take a few tries before you have it adjusted just right, so take your time and don't forget to install the cap when you're finished.
    So there you have it...and now, to see what each donor level has to offer, Click here.
    Old 06-04-2009, 03:24 PM   #3
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Once again, WetWilly answers it correctly and with every single detail, including pictures!!! Nice job!
    He's right, it's just the torque steer and is mostly corrected by that fin.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 06-04-2009, 03:45 PM   #4
    Gallery Images: 4
    Send Jimh23:
    Thanks for a quick and accurate reply.
    Old 06-05-2009, 10:52 AM   #5
    My pleasure Jimh23 and thanks indykoch, I have my moments......
    Steering on '96 Shabah jchemotti General Maintenance 5 05-15-2010 08:44 PM
    Steering Lube jakejorgenson General Maintenance 1 01-27-2009 03:25 PM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    It is hard being a Mariah owner! GreatShabah222 Introductions 2 05-02-2008 01:49 PM
    crashed hard drive!! moondance100 Introductions 4 11-29-2007 04:14 AM
    There are 286 users
