Hard Starting Once in Water
Old 07-07-2011, 04:51 PM   #1
julrich_32 is currently offline
My Year: 1990
My Model: 2000XL
My Engine: 5.0 Mercruiser Alpha I
Send julrich_32:
Default Hard Starting Once in Water
The first start each time after unloading off the trailer, it starts perfectly. Five minutes on the water before any serious boating, the boat doesn't want to start. The only way to get it started is to put it on full throttle and crank the engine for 5 - 10 seconds. It will finally catch enough to start. Once it starts, it runs great. You have to do it this way for the rest of the day to get it started. I'm worried it will eventually not start or burn up the starter.
Once I got it home after the weekend, I put the earmuffs back on it. I started it the first time and let it get up to normal operating temperature. Shut it down and waited a couple minutes before starting again. It started right up!! I did this a couple times and it started perfectly everytime. This makes no sense!!!!
I've change the fuel / water separating filter and in-line fuel filter. Not to mention a novice cleaning of the carburetor.
I'm hoping somebody will have a suggestion.
Thanks for your help.....
  • Old 09-06-2011, 05:10 PM   #2
    usmckao is currently offline
    My Model: 222 Z
    My Engine: 5.7 Mercruiser
    Send usmckao:
    Default Re: Hard Starting Once in Water
    If you think about it, you're not doing anything different by starting out of water. It doesn't make since to not start in water but does start out of water. Although you're not putting it under load out of water, and you aren't suppose to. May need to rebuild carbs, double check timming, possible tune up?, fluid levels. May be mechanical fuel pump issue.
    Old 09-07-2011, 03:06 AM   #3
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    The only thing that may be different is the boat may sit lower in the rear in the water than on the trailer. From what you describe it sounds like a possible flooding issue. What is you normal start routine? Are your engine temps the same when on the muffs and in the water? Has the fuel pressure been checked. What carb do you have? My last boat had the same problem until I rebuilt the carb.
    Happy Boating
    Dan
    1995 Z272 Barchetta
    fuel pump , hard starting , vapor lock
    Hard Steering Kirkyer Introductions 0 07-19-2009 12:53 PM
    hard steering duketter Original Mariah Talk 2 06-07-2009 02:47 PM
    Hard steering Jimh23 Original Mariah Talk 4 06-05-2009 10:52 AM
    It is hard being a Mariah owner! GreatShabah222 Introductions 2 05-02-2008 01:49 PM
    crashed hard drive!! moondance100 Introductions 4 11-29-2007 04:14 AM
    There are 317 users
