hard steering
Old 06-06-2009, 03:12 PM   #1
duketter is currently offline
Send duketter:
Default hard steering
1996 jubilee with bravo 3 drive. Sometimes it can be hard to steer, especially when first driving it at low speeds. I would think you should be able to steer this with one finger but it takes 2 hands. It does not have a trim tab as far as I can see to do any adjusting.
  • Old 06-06-2009, 09:54 PM   #2
    Default Re: hard steering
    Hi duketter,
    The Mercruiser models with power steering do not use the Trim Tabs, especially the Bravo III (the counter rotating props cancel the torque steer).
    Although the steering system is relatively simple, like many things on a boat, it can take some time to diagnose and repair the problem.
    Lets start with the obvious:
    Check the Power Steering fluid, see if it's full.
    Check to see if the belts are adjusted properly.
    Check for any leakage at the pump, hoses and at the ram.
    Have the Steering system and gimbal been lubed regularly or maintained?
    If the first three look OK, I recommend having a qualified service center check it out. You may have a bind in the steering cable or gimbal.
    Good luck,
    Old 06-07-2009, 02:47 PM   #3
    Send duketter:
    thanks for the reply. I checked fluids and all seem to be full. Not sure on regular maintenance since just bought the boat used. However it is in great shape and very well taken care of. I am thinking probably a bind in the steering cable or something. I will check there first and go from there.
    Thanks!
    Hard steering Jimh23 Original Mariah Talk 4 06-05-2009 10:52 AM
    Steering Lube jakejorgenson General Maintenance 1 01-27-2009 03:25 PM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    It is hard being a Mariah owner! GreatShabah222 Introductions 2 05-02-2008 01:49 PM
    crashed hard drive!! moondance100 Introductions 4 11-29-2007 04:14 AM
    There are 287 users
