Uptrim Issues
Old 06-16-2011, 02:24 AM   #1
KelRem is currently offline
My Model: Shabah 18
My Engine: 4.3L LX Alpha One
Send KelRem:
Default Uptrim Issues
I recently bought a 1996 Mariah Shabah 180 with the 4.3L Mercruiser. I've had it on the water twice now and have the same issue both times. I can down trim the outdrive with no issues in the water, when it's at the bottom of it's range of motion and I try to uptrim with the switch on the throttle, generally nothing happens. Every once in a while it will move up slightly then stop right away. When I try the trailer trim, it trims it right up with no issues. When I take it out of the water and play with the trim, everything works perfect. Anyone have any idea why this is only giving me a problem in the water??? Any help would be appreciated.
Kelvin
  • Old 06-16-2011, 03:09 AM   #2
    Shabah 198SE's Avatar
    Shabah 198SE is currently offline
    My Model: Shabah 198SE
    My Engine: 5.7L Alpha
    Send Shabah 198SE:
    Default Re: Uptrim Issues
    KelRem,
    It would seem that your trim limit switch may need adjusting. As it is, it may be okay for your on the warer needs. It may have been set that way deliberately.
    If you have the access, there should be trim limit switch adjustment instructions somewhere on this site.
    Shabah 198 SE
    Old 06-17-2011, 04:42 PM   #3
    My Model: Shabah 18
    Send KelRem:
    Originally Posted by Shabah 198SE View Post
    KelRem,
    Shabah 198 SE
    I'll try looking for the instructions. I did some more playing around with it today while the boat was on the trailer. The trim is still working good when trimming down, when I get past the 3/4 position down on the guage the uptrim refuses to work, but the Trailer tilt works fine. When I use the trailer tilt to move the outdrive above the 3/4 mark the uptrim switch works again... Thanks for the help.
    Kelvin
    Old 06-18-2011, 12:53 AM   #4
    My Model: Shabah 18
    Send KelRem:
    Issue appears to be solved now. Just had to do a minor tweak of the Trim limit switch.
    Old 06-18-2011, 02:23 AM   #5
    Send Shabah 198SE:
    KelRem,
    Great news!
    Shabah 198SE
    Alternator issues? bnussbaum Original Mariah Talk 5 06-05-2011 03:02 AM
    98 242 Z Nav light issues DRTutt Original Mariah Talk 2 05-10-2010 05:39 PM
    fuel issues murphysocc Mercury MerCruiser 9 09-14-2009 09:59 PM
    Prop Issues donb. Prop Talk 5 08-12-2009 09:23 PM
    starting issues murphysocc Mercury MerCruiser 2 07-13-2009 06:36 PM
    There are 307 users
