Wood
Old 03-23-2011, 11:19 AM   #1
DMK Thread Starter
DMK is currently offline
Send DMK:
Default Wood
Hi Everyone. I'm new to the Mariah group and have a question. My wife and I are looking at a 1995 212. I'm not completely familiar with the Mariah boat construction. Is there wood used in the structure of the boat? If so, where? What do I need to look for on a 1995 boat for any structural problems? The boat looks like it just rolled off the showroom floor (in the pictures, have not seen it in person). Just curious about how the wood is used and how often you see problems and what could cause the problem.
Thanks for your help.
DMK
  • Old 03-23-2011, 06:00 PM   #2
    Default Re: Wood
    "XL" CCA Pressure treated wood ( a couple of steps up from marine plywood) was used in the stringers, transom and in the deck and all were encapsulated in fibreglass. While wood problems in original Mariahs are very rare they are not unheard of. Floor problems would show up as 'squishy' when you step on it. Stringer problems would likely show up as stress cracking in the hull.
    One of our members (Provo) did a floor replacement & wrote up a 'how to'. You can check it out here.
    Old 03-23-2011, 08:16 PM   #3
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Default Re: Wood
    I would think if the upholstery is still good as new, the boat was stored inside and the structure is probably fine.
    Most wood issues are from sitting outside in the elements and the upholstery would tip you off if that was the case.
    Old 03-23-2011, 09:15 PM   #4
    DMK Thread Starter
    Send DMK:
    Default Re: Wood
    Thanks guys. It is a member,s boat. One owner. Always kept inside. I am going to get an inspection done by one of the area marinas. I am guessing they will check top to bottom.
    Wood Grain Dash Fix! Kuli Original Mariah Talk 3 04-30-2008 05:32 PM
    Wanted: Wood Grain Dash Douglas Alderman Mariah Parts For Sale & Wanted 2 04-30-2008 04:13 PM
    Rotted wood under sun deck Z210Shabah Original Mariah Talk 9 02-24-2008 07:59 PM
    Shabah - EFI and Wood Beltzington Original Mariah Talk 4 09-28-2007 10:26 PM
    Wood rot aquaknot Original Mariah Talk 2 08-28-2007 12:31 PM
    There are 287 users
