Shabah - EFI and Wood
Old 09-28-2007, 12:05 AM   #1
Beltzington is currently offline
Send Beltzington:
Default Shabah - EFI and Wood
Did Mariah ever eliminate wood from the hull? Chaparral started using composites in 2000.
Also, what year, if ever, did the V8 come with EFI?
Both are features I'm looking for in a bowrider.
TIA
  • Old 09-28-2007, 12:09 PM   #2
    aquaknot's Avatar
    aquaknot is currently offline
    My Model: z222 shabah
    My Engine: 7.4l EFI-Bravo 1
    Send aquaknot:
    My 99 has a 7.4 w/EFI.
    Tod
    1999 Mariah Z222, 7.4L MPI
    2004 Lowe 16 ft aluminum, 25hp 4stroke
    1995 pontoon 18 ft, 50hp mercruiser
    198? aluminum 14ft, 6.6hp fisherman
    Old 09-28-2007, 01:08 PM   #3
    EFI is kind of a generic term, it can cover various methods of fuel injection. There's throttle body injection, where the fuel is fed thru the throttle body (like an electric carb), and then there's MPI, which makes use of fuel rails and seperate injectors for each cylinder.
    The V8 EFI engines became available in 1996, as an option. In 98, they began offering the MPI systems, which are much more efficient and practical.
    The only wood, (that I'm aware of) during the later model years was located in the stringer structure, which were fiberglassed in and glassed over. That should not be a concern unless the boat you're looking at has been sunk.
    Old 09-28-2007, 07:50 PM   #4
    bdbyrnes's Avatar
    bdbyrnes is currently offline
    My Model: Talari z240
    My Engine: 7.4L V8 - Bravo III
    Gallery Images: 41
    Send bdbyrnes:
    Beltington - have you looked at the Z302?
    Brent
    Old 09-28-2007, 10:26 PM   #5
    Send Beltzington:
    Thanks for the replies. I'm looking for a 1999 - 2001 19' to 21' Bowrider. With V8 EFI (Throttle-Body or MPI) with composite stringers and floor. I was hopeful someone might know if this setup was ever offered by Mariah.
    Wood Grain Dash Fix! Kuli Original Mariah Talk 3 04-30-2008 05:32 PM
    Wanted: Wood Grain Dash Douglas Alderman Mariah Parts For Sale & Wanted 2 04-30-2008 04:13 PM
    Rotted wood under sun deck Z210Shabah Original Mariah Talk 9 02-24-2008 07:59 PM
    Wood rot aquaknot Original Mariah Talk 2 08-28-2007 12:31 PM
    There are 262 users
