Parts and Hatch Lift reccomendation?
Old 02-20-2010, 05:15 PM   #1
jhaag41 is currently offline
My Model: 1994 Z220 Talari 7.4L Bravo III
Send jhaag41:
Default Parts and Hatch Lift reccomendation?
I have a 1994 Talari Z220. My passenger dash (glove box) latch has broken and I need to replace it or repair it. Any suggestions on where to find a replacement or alternative repair?
My engine hatch lifts are failing. They are manufactured by acculift and are old enough to be unrepairable due to no replacement parts existing. I can buy the latest acculift linear actuator but they are 350.00 each and I really dont want to spend 700.00. Does anyone have suggestions on alternative actuators?
Any suggestions are greatly appreciated.
jason
  • Old 02-22-2010, 04:07 PM   #2
    tmonson's Avatar
    tmonson is currently offline
    My Model: 1999 Z272 Shabah,
    My Engine: 7.4L Bravo 3
    Send tmonson:
    Default Re: Parts and Hatch Lift reccomendation?
    I had a hatch lift fail on my 272 Shabah, it was an electric linear type. I looked at various replacement types and decided I could do better.
    I made up a hydraulic system on mine. It's smother and much, much faster than the original. I also mounted it right next to my actual trim pump for the drive so in the unlikely event that I have a failure I could switch hoses and have a backup trim pump.
    I purchased a used trim pump and reservoir assembly off of ebay. I did some research and got the output and and flow specs of the pump and matched it with a hydraulic cylinder. I made up the hoses and added a manual bypass valve that's accessible outside of the engine compartment in the event the batteries are dead.
    It was a lot more work than just replacing the original electric like for like, but it was well worth it!
    Old 02-22-2010, 05:47 PM   #3
    nelson's Avatar
    nelson is currently offline
    My Model: z240 Talari
    My Engine: 350 mag. alpha 1 gen.2
    Send nelson:
    I had my acculifts rebuilt at the same time I had the starter rebuilt at the same place .I think it was 150.00 each. they are a little slow but they work.I also at the same time replaced the plywood of the hatch whitch was waterloged.I think it lost 50lbs or so.
    Old 02-22-2010, 05:49 PM   #4
    nelson's Avatar
    Send nelson:
    after checking my records that was 150.00 for both
    actuator , glove box , plastic , replacement parts
    Help! Need info on Engine Hatch Lift - Z302 milemarker60 Original Mariah Talk 6 07-13-2022 10:58 AM
    Help with hatch lift - Need PICs of brackets stereoman405 Original Mariah Talk 14 06-01-2009 04:43 PM
    Sun pad lift moving very slooooowww...... launchpad Original Mariah Talk 1 04-21-2009 11:26 PM
    jubilee hydraulic hatch lift Gunner Projects 0 06-15-2008 07:49 PM
    96 talari Z240 Engine Hatch Lift Help WetWilly Original Mariah Talk 8 10-02-2007 12:30 PM
    There are 237 users
