Starting Problem
Old 08-24-2009, 10:53 PM   #1
mark shumaker is currently offline
My Model: 2000 252 Shabah 7.4L Bravo III
Send mark shumaker:
Default Starting Problem
Friends....My 2001 252 Shabah has developed a starting problem. When I turn the key most of the time the starter turns very slowly. Initially I thought it was a bad battery problem, however, I tested the battery and it was good. I cleaned the terminals and checked the cables. I'm wondering if it is a starter problem, however, I had it replaced about 18 months ago when it got wet after the automatic bilge failed to operate. Any thoughts or ideas? Thanks.
  • Old 08-25-2009, 12:08 AM   #2
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Default Re: Starting Problem
    How did you test the battery?
    Jim
    Old 08-25-2009, 02:58 AM   #3
    Provo's Avatar
    Provo is currently offline
    My Model: 1994 240 Talari 5.7Mag Alpha one
    Send Provo:
    Did you check the cables at the slave solenoid? As well as the solenoid itself.
    Provo ~1994 240 Talari~5.7 Alpha 1
    Old 08-25-2009, 07:43 PM   #4
    grommett's Avatar
    grommett is currently offline
    My Model: Z202 Shabah
    My Engine: 350 Magnum 5.7L Alpha
    Gallery Images: 10
    Send grommett:
    Hi Mark
    My problem (see my post - seized engine) started with a sluggish starter motor but good battery. 10 days after last running my boat I decided to start it on the trailer before launching and it would hardly turn. I changed the starter motor and it turned a couple of times, made a horrible noise and stopped.
    It turned out to be water in the cylinders had rusted the piston rings to the cylinders. It may be you have a completely different fault, but it might be worth removing the spark plugs and turning the engine over, if you get water coming out you might have leaky exhaust manifolds in which case changing them early could save you a lot of trouble.
    Old 08-28-2009, 10:16 PM   #5
    Send mark shumaker:
    [QUOTE=SEMIJim;17848]How did you test the battery? Jim...I took the battery to Auto Zone and they placed it on a testing machine. I have no reason to believe that they were pulling my leg given that they had motivation to sell another battery.
    Old 08-28-2009, 10:20 PM   #6
    Send mark shumaker:
    Originally Posted by grommett View Post
    Hi Mark
    That's scary. I might add that my boat stays on a hydrohoist and is never in the water more than 2 hours at one time.
    Old 08-29-2009, 02:42 AM   #7
    Hi mark,
    Did you replace it with a marine certified starter or one from an automotive store?
    If it isn't the starter, it's probably the ground or the main power cable from the battery to the starter. Check the cable for internal corrosion (This happened to our old boat,the cable was so corroded, the wires broke free of the starter terminal lug) then check the engine block for a solid ground back to the battery.
    Old 09-08-2009, 11:03 PM   #8
    Send mark shumaker:
    I'll definitely check the cables. Hopefully that's the problem.
    2000 258 Shabah, cold starting dvanluit Original Mariah Talk 8 08-15-2009 08:44 PM
    starting issues murphysocc Mercury MerCruiser 2 07-13-2009 06:36 PM
    bad problem dmg5606 Mercury MerCruiser 3 06-03-2009 12:20 AM
    Registration problem Anty2313 Introductions 3 03-31-2009 12:22 PM
    Name this Problem ShabahZ280 Original Mariah Talk 5 10-09-2007 01:41 PM
    There are 319 users
