2000 258 Shabah, cold starting
Old 08-12-2009, 12:46 PM   #1
dvanluit is currently offline
Send dvanluit:
Default 2000 258 Shabah, cold starting
I am looking for some help!
When I try to start my boat when it is cold, it takes about 5-10 minutes before it will turn over. When it has been started, there is no problem re-starting. Does anyone know if there is a time delay for the blower or something prior to starting or if there is a trick to start. I have tried everything.
  • Old 08-12-2009, 04:00 PM   #2
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Default Re: 2000 258 Shabah, cold starting
    Have you tried going thru the starting system with a meter to try to figure out where is the problem?
    Jim
    Old 08-12-2009, 05:12 PM   #3
    pimpadelic's Avatar
    pimpadelic is currently offline
    My Model: 1996 180 shabah 3.0L Alpha I Gen II
    Gallery Images: 7
    Send pimpadelic:
    if it only does it when its cold i would think the choke is not working properly.
    Old 08-12-2009, 07:07 PM   #4
    Send dvanluit:
    I havnt checked the starting system, I wondered if there is a relay of some type for the blower, almost like a glow plug. I wanted to check with other owners to see if they have this problem or knew something I didnt
    Thanks for the help
    Old 08-12-2009, 07:25 PM   #5
    SEMIJim's Avatar
    Send SEMIJim:
    We need more info. When you write "about 5-10 minutes before it will turn over," do you mean, literally, the engine doesn't even crank? Or do you mean it cranks, but will not start?
    I assumed, by "before it will turn over," you mean it wouldn't even crank.
    I know of no "timer" integral with the ignition and blower circuits, but that doesn't preclude the possibility.
    Assuming a gasoline engine: No, no "glow plugs."
    Jim
    Old 08-12-2009, 07:40 PM   #6
    Send dvanluit:
    I mean 5 minutes min. It wouldn't even turn over. I leave blower on with key off, tried with key on, nothing. I have even played with shut off swith, moving the shifter to make sure it is in neurtal.
    ONly time it started right away was last time I took it out of the water, I drove from home to boat ramp with the blower on (approx 15 min trip) and it started on first turn of the key. Thats why I wondered if it had a blower timer of somekind
    Thanks for the reply
    Old 08-12-2009, 10:08 PM   #7
    SEMIJim's Avatar
    Send SEMIJim:
    I don't know, guy. Our boat has no "startup delay" circuit interfaced with the bilge blower. (Ask me how I know ) Never seen such a thing mentioned here, either.
    I guess if you don't know enough about circuits, electricity and how these things work, you may have to pay somebody to check it out for you.
    Jim
    Old 08-14-2009, 01:28 AM   #8
    mfitz62's Avatar
    mfitz62 is currently offline
    My Model: 2000 258 Shabah, 7.4L Bravo III
    Send mfitz62:
    I have never heard of any time delay with a blower.
    What do you mean by cold starting?
    The boat has not been run for a few hours? days? or it is cold outside?
    Is there ever a time when you can walk up to the boat and hit the key and it turns over? If not, it sounds like you have a short in your ignition switch.
    Otherwise more information is needed.
    Old 08-15-2009, 08:44 PM   #9
    Hi guys,
    Mercruiser does have a starter delay system, but It is normally a part of the Keyless Ignition System. On boats with bilge blowers, entering the access code into the Keyless Ignition System automatically activates the blower, which operates on a three-minute timer then you can start the motor.
    dvanluit, I know this sounds weird, but next time, turn on the blower for 3 - 5 minutes then see if the motor will start.
    cold start 3.0 carb midwest mariah Mercury MerCruiser 12 07-03-2020 12:41 AM
    starting issues murphysocc Mercury MerCruiser 2 07-13-2009 06:36 PM
    2000 258 Shabah mfitz62 Introductions 4 07-05-2009 03:12 PM
    2000 182 Shabah donnae Original Mariah Talk 4 08-22-2007 11:05 AM
    There are 410 users
