Condensation in gauge
Old 05-04-2009, 11:32 PM   #1
Billyclub is currently offline
My Model: 1999 Shabah 182 Mercruiser 3.0L
Send Billyclub:
Default Condensation in gauge
Does anyone know how condensation can be removed from inside a gauge? My hour meter has quite a build up. Thanks
  • Old 05-05-2009, 02:54 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: Condensation in gauge
    Maybe a little heat? Say from a hair dryer?
    The bigger issue will be finding out where the leaky seal is so it doesn't re-occur.
    My Mariah
    Old 05-05-2009, 06:43 PM   #3
    I'm not sure if the hour gauge has a bulb socket on the back, but if it does, you can usually pull the bulb fitting out, thereby leaving an open hole at the back of the gauge, and you could let it dry for a day or so! Given this is if you have access to the back of the gauges! If not, it might be pretty difficult.
    One thing you might consider, contact Faria directly and see what kind of suggestions they offer!
    Old 05-05-2009, 07:38 PM   #4
    Send Billyclub:
    Thanks for the tips.
    Aftermarket Depth Gauge Kitto Original Mariah Talk 16 07-13-2010 02:02 PM
    Gauge Problems-SX18 Vilanova Sea Fox - Mariah Talk 3 01-18-2009 08:30 AM
    Dash Gauge Lights Out Roger Butterfield General Maintenance 20 01-12-2009 08:38 PM
    trim gauge no problem Original Mariah Talk 2 08-19-2008 09:18 PM
    Fuel gauge not working kingtide Original Mariah Talk 5 07-26-2008 06:34 PM
    There are 363 users
