Questions
Old 02-20-2009, 08:31 PM   #1
Provo's Avatar
Provo is currently offline
My Model: 1994 240 Talari 5.7Mag Alpha one
Send Provo:
Default Questions
Hello,
1. I would like to know what the Z options are. I have a 1994 Talari 240 but do not know if it is a Z model.
2. What is the small compartment that is built into the swim platform below the transom shower for?
3. I have what I think is a built in cooler in the center of the floor, am I correct?
4. My boat's weight is listed as approx 5000lbs is that wet or dry?
5. What is the differance between the acc lights and crys light switch?
6. Is there a wiring diagram avaialbe for my boat? I have removed all the add on circuits from previous owners and have started to lable the factory circuits.
Thanks for any info you can pass along.
Provo ~1994 240 Talari~5.7 Alpha 1
  • Old 02-20-2009, 09:12 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: Questions
    1. Z models are all tricked out. Power everything; drivers seat, engine hatch, telescoping sternlight, window defogger, windshield wiper. etc.
    2. It's a cooler/wet storage locker.
    3. The locker in the floor is for skis and such, though I guess you could use it as a cooler.
    4. Weights listed are usually the dry weight.
    5. Courtesty would be the cabin/cockpit lighting. I'm not sure about the accessory lighting. I don't have any.
    6. There are wiring diagrams available in the Original Mariah manuals and supplements subforum. As a contributing member you have access to that section.
    Welcome to the club!
    My Mariah
    Old 02-20-2009, 11:46 PM   #3
    Provo's Avatar
    Send Provo:
    I have another compartment behind the ski storage.
    Old 02-21-2009, 02:02 AM   #4
    From the pics in the 1994 brochure in our Promotional Materials archive it looks like an extra cooler / wet item storage area. If there is a drain hole then that is likely what it is.
    Old 02-21-2009, 01:45 PM   #5
    Welcome Prove, I have a 96 Z240 Talari and I'd like to make a few corrections if I may.
    1) We have a 94 Brochure and it list all the additional items that came on the "Z" models and like Z 202 said, it's pretty extensive over the non "Z" model, so as a Gold Member, you have access to it in the " Original Mariah Manuals and Supplements " in the "Original Mariah Boats" forum. You will also find #6 here as well like Z 202 said. BTW, the telescopic stern light wasn't available for the 94 or 96 Z240's.
    2) Z 202 is right about this compartment, it can double as a cooler for people in the water, or to store your ski ropes. It's a wet storage as there is the small drain hole in the bottom that takes on water because it's below the water line when the boat is at rest in the water or moving at slow speeds.
    3) I believe you were referring to the smaller locker behind the long ski locker, yes, that's a cooler and it should have a small chrome plastic strainer/plug at the bottom. The brochure has a great picture of this cooler. Under the front bow cushion there is another compartment that can double as a cooler too.
    4) The weight listed in the brochure for the 94 Z240 Talari was 3750 Lbs dry with the 5.7L engine, not 5000 Lbs.
    Well that's just my .02 worth...
    Good luck,
    Last edited by WetWilly; 02-21-2009 at 11:20 PM. Reason: spelling is not my strong suit....
    winterizing questions my97camaro Boating 101 6 10-28-2008 10:27 PM
    99 212Z questions Z212NH Original Mariah Talk 1 09-03-2008 02:54 AM
    Wakeboarding Questions ShabahZ280 Watersports 3 07-01-2008 06:54 AM
    new owner has questions geiffert Original Mariah Talk 3 05-28-2008 02:34 AM
    New to Mariah Questions to ask tmv Introductions 5 05-13-2008 04:08 PM
    There are 363 users
