changing power steering pump
Old 07-08-2008, 06:35 PM   #1
01DiabloMissouri is currently offline
Send 01DiabloMissouri:
Default changing power steering pump
How hard is it to change a power steering pump on a 2001 diablo 180? I noticed mine is leaking but can't seem to find where it is leaking from.
  • Old 07-09-2008, 01:41 AM   #2
    GrayDog is currently offline
    My Model: 1995 Davanti 205
    Send GrayDog:
    Your leak is probably coming from one of two places. The front bearing/seal or the connection where the low pressure hose clamps to the pump. Most likely the fron bearing/seal.
    I just replaced mine (50LX) two weeks ago. Not a bad job but will require the right tools. If the replacement pump doesn't come with a pulley, you will need a puller. These can be borrowed from your local auto parts store. You will also need a flare nut wrench for the pressure line connection as well as the rest of the normal wrenches and sockets required for removal. Most of these are metric. I would also recommend wrench for the large "nut" that the high pressure line screws into.
    Also, get a magnet on a stick to pick up all the tools and hardware that invariably falls into the bilge. When you remove the pump you will probably spill a fair amount of fluid so I would put some towels under the engine to keep things clean.
    Good luck
    Brad
    Old 07-09-2008, 01:51 PM   #3
    Thank you for the information. I will attempt this probably over the weekend!
    2000 Z260 Steering Cable sean77atx Original Mariah Talk 6 09-06-2022 08:56 PM
    Bilge pump issue adornare Original Mariah Talk 12 03-29-2010 03:30 AM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    Changing prop! Lars Prop Talk 8 07-04-2008 05:37 PM
    There are 263 users
