2000 Z260 Steering Cable
Old 04-11-2008, 09:11 PM   #1
sean77atx is currently offline
Send sean77atx:
Default 2000 Z260 Steering Cable
Just bought a Mariah and this boat is in great shape. I have found very few problems so far. My main issue right now is the steering. I literaly have to use both hands to turn the steering wheel. I plan on changing both the steering and shift cable before I take it out again. I have all the manuals and I am going to start going through them to see if there is any info on the steering and shift cable parts. Hoping for part numbers or lengths.
Does anyone know what the replacement steering and/or shift cable is for Z260?
Thanks for any help. Looks like it will be a job getting that cable out and replaced.
  • Old 04-11-2008, 09:56 PM   #2
    MariahMan's Avatar
    Status: Admin Guy
    My Model: 252 Shabah
    Gallery Images: 211
    Send MariahMan:
    Your problem could also be caused by a malfunctioning power steering pump or something else in that system. That would definetely explain the difficulty in steering. Be sure to also check the hoses and such on the pump while you check the cables.
    Be sure to let us know what you find.
    -Ryan
    ThunderShark Web Solutions
    Old 04-16-2008, 03:36 AM   #3
    Rick is currently offline
    Send Rick:
    Default Steering Cable
    I replaced the cable on my '93 Z212 for the same reason, as it was very stiff to turn the wheel. I thought I was going to twist the steering wheel off the shaft. It seems the grease inside the cable became hard causing the stiffness and I couldn't come up with a reasonable way to clean it out or add new grease. My steering was a Teleflex rack and pinion setup with a 15 foot cable. It took some effort and contortions to remove the various nylon ties holding the cable in place in order to R&R.
    Old 04-17-2008, 10:07 PM   #4
    Send sean77atx:
    Replaced the cable this morning. The old one was in real bad shape. Wasn't too bad changing it. My arms don't look to good right now though. Took two hands to turn the wheel before and now drove it for a quick spin and can steer with one finger. I did look at the power steering. The fluid looks bad. Very dark. Going to change that out when I get the chance. Not too many projects left before I start taking it out this Summer!
    One down and a few more to go.
    GregT likes this.
    2000 Z260 Lake Travis, Texas
    Old 09-06-2022, 12:53 PM   #5
    Skifreek is currently offline
    My Model: Z260
    Send Skifreek:
    Default Re: 2000 Z260 Steering Cable
    Do you have to Length and style of the cable? I just broke mine this weekend and have to replace it on my Z260.
    Old 09-06-2022, 03:33 PM   #6
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Manufacturer, model and length are printed on the jacket of the cable.
    GregT likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 09-06-2022, 08:56 PM   #7
    My Model: Z260
    Send Skifreek:
    Yeah I looked. All it says is imported from Italy. Seeing what someone else replacement was.
    z260 fuel consumption/reviews/specs koresample Original Mariah Talk 10 04-16-2008 08:12 PM
    new extended swim platform on Z260 S.L.P. Original Mariah Talk 9 04-11-2008 09:15 PM
    There are 334 users
