Electrical smoke smell help
Old 06-21-2016, 09:27 PM   #1
62 driver is currently offline
My Model: 202 Shaba
My Engine: 4.3 L
Send 62 driver:
Default Electrical smoke smell help
Found the tank sender and removed it to suck the gas out. Drained the fuel filter. Put new gas in with a new battery. Started right up after sitting 4 years. Did a shake down run. Could smell electric smoke smell around the passenger feet area. Just below the glove box. Stopped after 30 minuets. Ideas?
  • Old 06-22-2016, 02:26 AM   #2
    Shabah93 is currently offline
    My Model: Shabah 198
    My Engine: 5.0 EFI OMC Cobra
    Send Shabah93:
    Default Re: Electrical smoke smell help
    Any way that mice might have chewed the insulation from the wires while it sat?
    Old 06-22-2016, 02:34 AM   #3
    Send Shabah93:
    I believe the only thing in that area is a speaker and courtesy light. Do both still function?
    Old 06-22-2016, 10:59 AM   #4
    My Model: 202 Shaba
    My Engine: 4.3 L
    Send 62 driver:
    No mice that's for sure. Yes the light and speaker over their work. Nav lights work. My boat has cut in headlights. They don't work. Never did. All the fuse's are good and no hot wires under the dash.
    Old 06-22-2016, 05:31 PM   #5
    Send Shabah93:
    Sounds like a mystery. Luckily the smell disipated and so far no harm has come to your boat. Be thankful.
    Old 06-23-2016, 05:24 AM   #6
    My Model: Z276
    Send Brian Belcher:
    Please keep a fire extinguisher handy. Smoke is like sound. You'd bet your last dollar the sound is coming from the front wheel and it turns out to a rear driveshaft. Been down that road of thinking the burning smell is coming from one place and it turns out it was from the opposite side.
    Also, is there anyway it wasn't "electrical" smelling ?
    Where is your bilge pump ? Is it working ?
    Gasoline smell, engine compartment! Danish Mariah SX 18 Owner Mercury MerCruiser 4 07-17-2018 02:55 AM
    Raw gasoline smell Paul F Original Mariah Talk 1 06-23-2015 01:10 PM
    Blue smoke from exhaust jsamaroo Mercury MerCruiser 6 07-15-2009 03:56 PM
    Fuel Smell in Cabin Roger Butterfield Mercury MerCruiser 1 04-15-2009 03:29 PM
    There are 245 users
