Blue smoke from exhaust
Old 07-13-2009, 05:14 PM   #1
jsamaroo is currently offline
Send jsamaroo:
Default Blue smoke from exhaust
My 98 shabah 202 blows blue smoke from the exhaust when I am at low speeds. Any ideas on what this is?
  • Old 07-14-2009, 11:48 AM   #2
    Default Re: Blue smoke from exhaust
    Hi jsamaroo, blue smoke normally indicates burning oil, black smoke indicates too much fuel and for land vehicles, white smoke indicates water in the exhaust system (doesn't work for our boats, because there is supposed to be water in our exhaust all the times).
    You can check your spark plugs to see which cylinder is using oil.
    Old 07-14-2009, 01:42 PM   #3
    Send jsamaroo:
    If a cylinder is using oil, what do i need to do, change the head casket? Thanks.
    Old 07-14-2009, 07:58 PM   #4
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    The most likely candidates are worn piston rings or worn valve guides.
    How many hours on your engine?
    My Mariah
    Old 07-14-2009, 08:00 PM   #5
    Send jsamaroo:
    The engine only has like 235 hours on it.
    Old 07-15-2009, 04:38 AM   #6
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    I hesitated to comment, esp. as my comments would've constituted bad news, but I fear Z 202 is probably right .
    Jim
    Old 07-15-2009, 03:56 PM   #7
    Send 300sflyer:
    That seems like very low hours for an engine to be burning oil already.
    As Wet Willy suggested, pull your spark plugs one at a time, to see if any are fouled up with oil. Does the level of oil seem to be dropping the more the engine is running? What oil are you using?
    1996 Shabah Z212 Limited Edition Blue Hull sydsam05 Mariah Boats For Sale & Wanted 0 06-15-2009 12:51 AM
    blue-green mariah color? difran25 Original Mariah Talk 4 06-07-2009 11:38 PM
    Optima Battery...Yellow Or Blue? jasfiveo Original Mariah Talk 2 03-12-2009 04:40 PM
    Exhaust TALLRAM Original Mariah Talk 2 12-17-2008 05:08 PM
    Blue Bimini Top Gary Black Original Mariah Talk 0 07-11-2008 05:58 AM
    There are 290 users
