Gasoline smell, engine compartment!
Old 07-05-2015, 07:38 PM   #1
Danish Mariah SX 18 Owner is currently offline
My Year: 2006
My Model: SX18
My Engine: 3.0 - 135 HK
Send Danish Mariah SX 18 Owner:
Default Gasoline smell, engine compartment!
Hi,
I don know if this is a common problem for boats with carburetors, but
im not feeling comfortable with the smell og gasoline from the engine compartment.
and i want to find the reason.
I have checked all fuel lines and connections, and no leaks where found.
my personal conclusion is that the carburetor is the source.
Does any of you have some experiences, or advice what could be the reason.
My boat is a 2006 Mariah SX18 with 3.0L engine.
Thanks in advance
  • Old 07-06-2015, 02:33 AM   #2
    Default Re: Gasoline smell, engine compartment!
    No, its not a 'common' issue with carbureted boat motors and it's something that you need to find and fix asap before your boat (and anyone in it) goes 'boom'.
    Old 07-06-2015, 05:27 AM   #3
    My Year: 2006
    My Model: SX18
    Thanks Mikey,
    I think i will dismantle the carburetor and buy a repair kit, to see if that solves the problem,
    Best regards
    Old 07-16-2018, 01:44 AM   #4
    Clv1 is currently offline
    My Year: 2008
    My Model: SX18
    My Engine: 4.3 Merc
    Send Clv1:
    Did the carb rebuild fix the issue? I am having the same issue.
    Old 07-17-2018, 02:55 AM   #5
    pole trick is currently offline
    My Model: 180 Shabah
    My Engine: 4.3 Merc
    Send pole trick:
    Can be very serious issue. A boat exploded this spring on lake by me. Was a dock install boat had fuel leak. Blew the deck off boat and operator up in air he land back in boat on fire and luckly was able to jump in to lake also while being on fire. Burned 75% of his body. His family watch from shore as it happen.
    Engine compartment storage Kirk and Lori Original Mariah Talk 3 05-15-2019 02:20 AM
    Raw gasoline smell Paul F Original Mariah Talk 1 06-23-2015 01:10 PM
    Crack inside engine compartment alang424 Original Mariah Talk 1 05-14-2015 02:17 PM
    Engine compartment walls Lucky14 Sea Fox - Mariah Talk 3 05-09-2015 12:52 AM
    Engine Compartment walls solidaudio1 Original Mariah Talk 4 06-22-2012 01:58 AM
    There are 374 users
