Interior Panel Lose (Throttle Mounting Panel)
Old 06-06-2016, 04:35 PM   #1
iced98lx is currently offline
My Model: Z200 Shabah LE
My Engine: 5.7L Alpha
Send iced98lx:
Default Interior Panel Lose (Throttle Mounting Panel)
Hey all-
Have an issue where the panel the throttle mounts to is lose, appears wherever the screws screw into are stripped. This is the panel:
(NOT MY BOAT)
Anyone tackled reinforcing this panel before?
  • Old 06-07-2016, 12:01 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Interior Panel Lose (Throttle Mounting Panel)
    You can try over drilling and installing plastic hollow wall anchors. It's worked for me in the past. The other option is to use larger diameter screws.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    iced98lx (06-07-2016)
    Old 06-07-2016, 01:35 PM   #3
    Send iced98lx:
    thanks Steve, I'll take a look adn see if I can get some anchors behind the screws. Do the screw covers just pop off?
    Old 06-07-2016, 02:00 PM   #4
    My Model: Z280
    Yes, carefully pry off using a flat blade screwdriver.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-07-2016, 08:07 PM   #5
    My Model: Z276
    Send Brian Belcher:
    Another solution is a well nut. I've replaced a few screws on mine with them. I use to use them for permently mounting a nut where you could never get a loose nut onto a bolt, like dash panels and the skins on our buggies. You can do the rubber surround or, the ones I use, a collapsing metal type. If interested, just reply and I'll get more info on the metal ones
    Old 06-07-2016, 08:13 PM   #6
    My Model: Z276
    Send Brian Belcher:
    Remembered what the metal ones are called and it's good info for others with similar repairs.
    Nutcert or Rivcerts or Rivnuts
    The tool ($37) collapses a section of the nut and locks the nut permently on the media. It's like a 17/32 hole.
    Old 06-07-2016, 08:32 PM   #7
    Send iced98lx:
    Thanks Brian, great options if I can't figure out how to make the current screws work!!
    Fuse Panel ezgoin45 Original Mariah Talk 6 07-30-2019 03:02 PM
    Interior Side Panel Removal HappyOurs222 Original Mariah Talk 20 07-31-2016 09:59 AM
    fuse panel TomB Original Mariah Talk 3 09-20-2015 02:51 AM
    Have you seen this new Switch panel? recelect Chit Chat/Off-Topic 4 12-14-2010 04:33 AM
    Wanted: Glove Box Panel snobordin8 Mariah Parts For Sale & Wanted 2 12-16-2009 05:05 PM
    There are 349 users
