Interior Side Panel Removal
Old 04-10-2015, 03:04 PM   #1
HappyOurs222 is currently offline
My Model: 222
My Engine: 5.7L Alpha
Send HappyOurs222:
Default Interior Side Panel Removal
Does anyone know how to remove the interior side panels or know of an info source for the same? I want to replace the carpet with vinyl in my 222.
  • Old 04-10-2015, 08:07 PM   #2
    Dave Z252 is currently offline
    My Model: z252 shabah
    My Engine: 7.4l bravo III
    Send Dave Z252:
    Default Re: Interior Side Panel Removal
    I don't know if is the same, but on my 96 252 the panels lift up and off. There are no screws holding mine on, just aluminum L brackets.
    Old 04-10-2015, 11:50 PM   #3
    My Model: 222
    Send HappyOurs222:
    Dave,
    Thanks for the response. It sounds almost too simple to be true but I will give it a try. This seems like such a common matter that I'm surprised I didn't get several responses and maybe I will over the weekend. I know this is a knowledgeable group who love these old boats.
    Tom
    Old 04-11-2015, 01:31 AM   #4
    jayws6 is currently offline
    My Model: Z255 Shabah
    Send jayws6:
    On our '97 Z255, the upper side panels lift up and off like Dave mentioned and the lower carpeted side panels that run along the floor are screwed into place. You have to hunt around a little to find the screw heads buried in the carpet.
    Old 04-11-2015, 04:48 PM   #5
    Bill's Avatar
    Bill is currently offline
    My Model: Z222
    My Engine: 496 HO Bravo lll
    Send Bill:
    Hi I have a Z222 2001 I read somewhere that there are screws under the buttons if you pop the button covers off you will see them I have the buttons on mine But I have never tried to remove ther panels YET then like everybody else said you just lift up and remove the panels
    Hope this helps
    Regards
    Bill
    2001 Z222
    Old 04-13-2015, 08:36 PM   #6
    My Model: 222
    Send HappyOurs222:
    Thanks for replies and I tried lifting front, rear and center with all my strength and neither side would budge even the smallest amount. I think I'm going to just lay the vinyl right up to the carpet on the side panels and maybe, with any luck, I can even force the vinyl under that carpet so I have a nice finished edge.
    Old 04-23-2015, 12:06 AM   #7
    busby1981 is currently offline
    My Model: 222/Z222
    My Engine: 5.7 alpha 1
    Send busby1981:
    I have just redone my 2000 222 and there is screws at the top of the panel that you need to remove
    Old 04-23-2015, 12:12 AM   #8
    My Model: 222
    Send HappyOurs222:
    So if I locate and remove the screws at the top, will the side panels just lift out?
    Thank you HappyOurs222 for this useful post!
    Chasekwood (05-31-2020)
    Old 04-23-2015, 12:35 AM   #9
    My Model: 222/Z222
    Send busby1981:
    There pretty hard to get out of there ,Takes a little maneuvering to get them out but yes mine came out after I removed to screws. You will also need to remove the seat post to.
    Old 04-23-2015, 12:40 AM   #10
    My Model: 222
    Send HappyOurs222:
    Thanks Busby. I probably won't get to this until my son (the assistant) visits in late June but I will look in the next few days to see if I can locate the screws.
    oil sump removal bustah Volvo Penta 3 11-14-2013 04:39 PM
    Wanted: port side camper panel BDQ Mariah Parts For Sale & Wanted 0 07-08-2012 10:53 PM
    remove interior side panels 96 talari z220 scott3558 Original Mariah Talk 7 08-27-2010 10:56 PM
    Need help With dashboard Removal niceguy167 Original Mariah Talk 2 06-08-2009 02:08 PM
    Side Panel removel jeffryb Original Mariah Talk 2 04-12-2009 12:55 PM
    There are 342 users
