fuse panel
Old 09-18-2015, 11:53 PM   #1
TomB is currently offline
My Model: MX20
My Engine: 5.8 HO Omc King Cobar
Send TomB:
Default fuse panel
can anyone tell me where the fuse block on panel is on a 1992 MX20 ?
  • Old 09-19-2015, 04:54 PM   #2
    Default Re: fuse panel
    Probably in the same place it is on all smaller Mariahs, up underneath the console against the hull.
    Old 09-20-2015, 12:00 AM   #3
    My Model: MX20
    Send TomB:
    Thanks Mickeyt , I found the fuses before I read your post , but you are exactly right . They are under the console on the side of the hull . Thank you for responding . Now I have a fuel problem , seems to be the fuel pump . I thought a 1992 would have a in tank fuel pump , but this one has a mechanical pump . Looks like it is going to be a bugger to change . Will most likely have to remove the power steering pump in order to get to it . Do you or anyone else who may view this post have any suggestions on a better way to change this pump ? Do you know what the fuel pressure should be on this 1992 5.8 HO King Cobra OD ? Should I just block this pump off and install a electrical pump ?
    Old 09-20-2015, 02:51 AM   #4
    I'm sure the information is in one of the service manuals that this site has for contributing members but if were mine i would take option 2, block off the original fuel pump & install an electric one.
    Fuse Panel ezgoin45 Original Mariah Talk 6 07-30-2019 03:02 PM
    Fuse Panel Frustration! larryrawie Original Mariah Talk 2 08-17-2014 10:56 PM
    Fuse Panel Layout MichelleJ Introductions 3 07-13-2014 03:12 PM
    2000 Jubilee 244 fuse panel nmweber45 Original Mariah Talk 1 06-23-2012 05:29 PM
    There are 352 users
