Paddle Wheel Location With Smart Tabs
Old 08-06-2015, 01:30 AM   #1
tdmaker is currently offline
My Model: Z221 Talari
My Engine: 350 Mag MPI Alpha One
Send tdmaker:
Default Paddle Wheel Location With Smart Tabs
So I purchased a set of SX Smart Tabs to put on my '98 Z221. I've already run into a snag, the small paddle wheel sensor is mounted right where I need to mount the left Smart Tab. So I'm going to have to move it. Should I move it in towards the center of the boat or outwards further from the center? Or does it matter? And on a side note, does anyone know what the heck it does?
  • Old 08-06-2015, 02:00 AM   #2
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Default Re: Paddle Wheel Location With Smart Tabs
    I've read the further out the better.
    Old 08-06-2015, 02:04 PM   #3
    Paddle wheel is for the trip meter. Suppose to give you an idea of distance traveled. I mounted mine towards the center of hull- not the best idea. The hydraulic lines for the trim rams knock it off where its is located on my boat now. I need to mount it farther out but I'm tired of pulling holes in the transom. Maybe this winter I fix it and take the boat to the fiberglass guy and have him clean up the holes properly.
    Old 08-08-2015, 02:16 PM   #4
    Send tdmaker:
    So I decided to move it in. The wires wouldn't be long enough to move it to the outside, plus it would have made the Smart Tabs move inward more. I'm off to the lake this morning so I'll find out today if it was the right move or not.
    Old 08-10-2015, 11:09 PM   #5
    My Model: 180 Diablo
    My Engine: 3.0 Mercruiser
    Send TN_Diablo:
    You will like the Smart Tabs but you probably shouldn't have put them on upside down .
    I probably wouldn't worry much about the location of the paddle wheel if it still reads something. Do you really pay attention to it anyway?
    Repairing holes, cracks, minor things is pretty easy. You could fill the hole first with fiberglass resin I suppose but I would just use a gel-coat repair kit. I used this once for some minor hull damage and you can hardly tell (if you can tell) where the repair is. Mix, fill area, cover with plastic sheet until set, sand smooth and polish. Much easier than bodywork on a car.
    Old 06-02-2016, 03:25 PM   #6
    My Model: Z202
    Send Firestone:
    How did the trim tabs work out? I just bought a Z202 with planing plate and wonder if I should switch over to the Smart tabs?
    John
    Old 06-02-2016, 07:52 PM   #7
    Send tdmaker:
    The Smart Tabs work as advertised. I was skeptical at first, but they surpassed my expectations. I highly recommend them.
    Thank you tdmaker for this useful post!
    Firestone (06-02-2016)
    Old 06-07-2016, 05:23 PM   #8
    My Model: Z202
    Send Firestone:
    Did you end up using the 60# or 80#? What size did you use 9.5" or 10.5"? Thanks for the pictures! About how far off of the outside edge did you end up installing the smart tabs?
    John
    paddle wheel , smart tabs
    Smart Tabs ColoradoDiablo Other For Sale 3 03-16-2014 05:23 PM
    paddle wheel megawatt72 Original Mariah Talk 11 06-22-2012 07:42 PM
    Smart Tabs karmann Original Mariah Talk 13 07-22-2009 06:21 PM
    There are 343 users
