Can't Adjust Analog Clock
Old 05-25-2016, 01:36 PM   #1
shabahdabbado is currently offline
Send shabahdabbado:
Default Can't Adjust Analog Clock
In a 1999 Z222 the analog clock still ticks, but it seems the knob to adjust the time is stripped out, turning it doesn't change the time, and pushing it in a bit or pulling it out a bit doesn't seem to change that. Any suggestions?
  • Old 05-25-2016, 11:28 PM   #2
    Brupa's Avatar
    Brupa is currently offline
    Status: BJL716 Z245
    My Year: 2002
    My Model: 2002 Z245 STC
    My Engine: MX6.2L BRAVO III
    Gallery Images: 12
    Send Brupa:
    Default Re: Can't Adjust Analog Clock
    Send it to Faria, they will fix it for a nominal fee. That's what I did with mine. Had the same problem
    Old 05-26-2016, 12:52 AM   #3
    Send shabahdabbado:
    Awesome, thanks!
    Old 06-02-2016, 05:53 PM   #4
    What was their "nominal fee" Brupa? If you don't mind sharing? My clock's starting to go too...
    Old 06-02-2016, 06:00 PM   #5
    Send shabahdabbado:
    According to their website, $75.
    On-Line Repair - Entry Page
    ShabahZ280 likes this.
    Old 06-02-2016, 06:57 PM   #6
    Brupa's Avatar
    Status: BJL716 Z245
    My Year: 2002
    Gallery Images: 12
    Send Brupa:
    I believe when I had it done it was $55. But it was a few years ago.
    Old 06-02-2016, 07:15 PM   #7
    Send shabahdabbado:
    So far on my fall/winter punchlist:
    Send back clock to Faria for repair
    Send back depth finder gauge to lowerance for repair
    Replace seat bushings so it isn't so wobbly
    Repair/replace hatch linear actuator
    Replace lights with LEDs
    Replace vinyl on sun deck/back seats
    Brian Belcher and Firestone like this.
    Old 06-02-2016, 08:38 PM   #8
    Sounds like some good projects in line for the off-season!
    Just an FYI though, if you've got an issue with your depth gauge, and it's just flashing .5 or something, double-check to make sure the transducer is still epoxied into the hull in the bilge. This seems to be a common issue. If this isn't the problem, I'm afraid I have some bad news. Lowrance discontinued and no longer supports the 3500 series depth gauges. They abandoned the 192kHz technology many many years ago (10+!). And of course, there's no other units that are compatible with that specific transducer, so the whole system needs to be replaced. If you're one of the lucky few who can find used 3500's on eBay, they can sometimes get into the price of the new Faria and Lowrance systems! The new systems are pretty nice, and include things like water temp too! Just a little food for thought.
    Old 06-02-2016, 09:01 PM   #9
    Send shabahdabbado:
    It's not that, it just has dim segments unless you push on it a bit. Pretty common seven segment display issue.
    Old 06-03-2016, 08:19 AM   #10
    My Model: Z202
    Send Firestone:
    Your list is about the same as mine lol
    John
    hour clock Jerry Keane Original Mariah Talk 2 07-27-2014 02:44 PM
    how to adjust the trim megawatt72 Original Mariah Talk 7 07-12-2012 01:53 PM
    Radio clock and presets Paul F Original Mariah Talk 3 08-02-2011 03:45 PM
    Clock not Working '97 Shabah coxgreen Original Mariah Talk 0 04-29-2009 09:16 PM
    For Sale: Mariah Dash Clock mikeyt Mariah Parts For Sale & Wanted 3 07-18-2008 03:09 PM
    There are 259 users
