hello, can you help electrical fault 1999 182
Old 05-06-2015, 01:47 PM   #1
bushead is currently offline
My Model: 182
My Engine: 3.0L Alpher 1
Send bushead:
Default hello, can you help electrical fault 1999 182
Can any one help?
I have an electrical fault on my 1999 182 in has a mercruiser 3.0. The 20amp fuse supplying power to the ignition keeps blowing and i lose all power apart from to the trim switch. I have now replaced thew fuse board as it was corroded and looking pretty nasty !! but this hasn't solved the problem. it only seems to be an intermittent fault but once the fuse blows it keeps blowing. also i have noticed that once the fuse has blown and been replaced the boat will turn over but not fire (start) and the wire from the fuse board to the ignition got worryingly hot. iv read some bits on here so am going to clean up the ground block and connectors tonight and have a look at main mercuiser plug and circuit breaker but any other advice would be gratefully received thanks in advance
Also dose any one have a wiring diagram other than the one in the owners manual ?
Thank You
  • Old 05-06-2015, 04:50 PM   #2
    Shabah203's Avatar
    Shabah203 is currently offline
    My Model: Shabah 203
    My Engine: Volvo Penta 4.3 GL Duo
    Send Shabah203:
    Default Re: hello, can you help electrical fault 1999 182
    My five cents worth:
    Sounds to me like the wiring might have melted somewhere downstream. So you keep having a short. I would follow the wiring from the front to the rear, Probably runs behind the sidepanels, and use your nose! If you smell burned plastic, you must be close...
    The fact that it is intermittend, but once it goes it keeps going might be that it only shorts when it gets hot; the wire expands and than touches the other wire. When it cools down it might just shrink enough.
    Old 05-06-2015, 04:55 PM   #3
    My Model: 182
    Send bushead:
    Sounds possible I'm going to investigate a little deeper thank you
    Electrical Help norri Original Mariah Talk 4 11-23-2013 01:37 AM
    1999 260MCC electrical questions Spnky168 General Maintenance 0 09-16-2009 08:47 PM
    Electrical issue! Who's the electrical guy? Eddie Original Mariah Talk 9 05-06-2009 04:52 AM
    Electrical Fix Straad General Maintenance 2 08-28-2007 12:26 AM
    There are 219 users
