Electrical Fix
General Maintenance
Old 08-27-2007, 02:24 PM   #1
Straad's Avatar
Straad is currently offline
My Model: Barchetta 182
My Engine: 4.3 Merc
Gallery Images: 8
Send Straad:
Default Electrical Fix
launched the boat, engine started fine
went to trim down motor and just got a fast click,click,click,click
this had happened a few weeks back when it rained a ton and the boat got wet but the next day was fine
well this time i was out with a buddy that is an electrician
so he starts poking around
(should note this is on a 1995 Barchetta 182)
well on your battery is the two main poles positive and negative, like a car
then there are smaller poles with wing nuts on them
well the negative wing nut has 2 wires
one leads to what i believe is the fuel pump
and the other to the tilt trim electric hydraulic pump
the two "o" connectors on this pole are copper and didnt appear to be corroded to me, but my electrician friend noticed they were green (what happens when copper corrodes)
we pulled them off,
scraped them with a knife we had onboard
reattached them
and everything worked fine
so it was a very easy fix, if you knew where to look, so i thought i would post here in case anyone else has a similar problem
went on to have a great day of boating which could have been ruined
moral of the story...allways take an electrician fishing
Straad
1995 Barchetta 182, 4.3L
Southern Mid-Michigan
  • Old 08-27-2007, 09:21 PM   #2
    yep....you can always use the electrician as bait if nothing goes wrong with the boat.
    Old 08-28-2007, 12:26 AM   #3
    changed the title, seemed more appropriate.
    This is a great point to be made, for some reason our boats electrical connections are very susceptible to corrosion. Clean your contacts first if you're having any strange electrical behavior!
    Wanted: Electrical Wire Diagram (99 Jubilee) 214 Douglas Alderman Mariah Parts For Sale & Wanted 3 04-13-2008 05:22 AM
    Marine ACDC electrical site mikeyt General Maintenance 0 03-05-2008 12:37 AM
    electrical problem nickc Sea Fox - Mariah Talk 4 02-24-2008 06:34 PM
    There are 318 users
