oil sump removal
Volvo Penta
Old 10-24-2013, 11:19 AM   #1
bustah is currently offline
My Model: 182 Shabah
My Engine: 4.3l volvo penta
Send bustah:
Question oil sump removal
Hello
Can any one tell me is it possible to remove the sump and replace the gasket in a 2000 182 with a
Volvo penta 4.3 L v6 while it is still in the boat any help or suggestions will be appreciated
  • Old 10-24-2013, 10:39 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: oil sump removal
    I don't have a 4.3L but I doubt that you can remove the oil pan without pulling the motor/outdrive.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    bustah (10-25-2013)
    Old 10-25-2013, 12:01 AM   #3
    There is no way you'll get it clear of anything in the bilge.
    Sorry..........gotta pull motor. At least most of the way out.
    Just not enough room in a 18' boat.
    Thought: If I were going that far , I'd definitely replace the rear main seal while I was that far into her.
    bustah (10-25-2013)
    Old 11-14-2013, 04:39 PM   #4
    domraga's Avatar
    domraga is currently offline
    My Model: 218
    My Engine: Volvo 5.7GL / SX-M
    Gallery Images: 32
    Send domraga:
    Negative, make sure you run the engine and leak check it before you put it back. The RTV seals on front and rear have a habit of leaking...
    4.3 engine removal Monty Mercury MerCruiser 3 07-30-2013 12:33 AM
    Need help With dashboard Removal niceguy167 Original Mariah Talk 2 06-08-2009 02:08 PM
    Paint removal?? stereoman405 Original Mariah Talk 9 05-06-2009 10:31 AM
    sump pump Digby Original Mariah Talk 0 07-30-2008 04:33 AM
    There are 285 users
