Interior Side Panel Removal
Old 04-23-2015, 12:48 AM   #11
busby1981 is currently offline
My Model: 222/Z222
My Engine: 5.7 alpha 1
Send busby1981:
Default Re: Interior Side Panel Removal
Your welcome! I have completely gutted the inside of my boat and done everything myself. It was fun and was a great winter project beats paying a ton of money to have someone else do it. Good luck and have fun. If you have anymore questions just ask.
  • Old 05-02-2015, 06:02 AM   #12
    dafucwuzat is currently offline
    My Model: talari 221
    My Engine: merc 5.7 b3
    Send dafucwuzat:
    Lower panels have screws hidden in the carpet if it's like my 97 talari. Uppers on mine lift out. Mine is gutted as I type.. Sorry, but don't see the fun. Just got done glassing new floor. Good luck. Obtw, if you are trying to remove bottom, try GENTLY prying top of panel out and looking through gap for screws then dig through carpet to find the head
    Old 07-17-2016, 01:04 AM   #13
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    I just removed the padded panels up in the bow section of my '98 202 and my son and I tried to remove the longer side panels from the main cabin. We popped off the screw cover buttons (need to find more of those) and unscrewed them. I thought that the only thing left holding them is the L brackets and we could lift them off. No dice... They wouldn't budge. I wonder what I am missing?
    I have two 1/2" thick 4' X 8' white King Starboard sheets so I can replace my sundeck/engine cover and my bow seating pieces. I thought that I have enough to replace those long padded panels if I could get them off.
    1998 202 Shabah 5.0L Alpha 1
    Phil Levine
    1998 202 Shabah
    Old 07-19-2016, 03:52 AM   #14
    baholtz is currently offline
    My Engine: 305
    Send baholtz:
    There are screws behind the buttons that go into the fiberglass. Also, they are burried in the carpet at the bottom.
    Old 07-21-2016, 03:41 PM   #15
    I don't know if your panels are like my old Z250, but there were also screws located underneath the decorative vertical "straps" of vinyl.
    Never could confirm if these were originally done at the factory, or something the previous owner had done, but give it a try, pull them aside a little bit and see if you can see holes underneath. If so, then that's what might be holding them in place! I was able to fully remove my panels after removing these screws.
    Old 07-26-2016, 06:01 AM   #16
    pllevine's Avatar
    Send pllevine:
    I wish my interior looked like that.... No, we don't have any vertical straps...
    Phil Levine
    1998 202 Shabah
    Old 07-26-2016, 08:43 PM   #17
    My Model: Z202
    Send Firestone:
    I found the screws under the vertical straps just like ShabahZ250 said. Mine have pulled out on one area and I need to repair the damaged holes. I will try to take some pictures for you Friday if it will help.
    John
    Old 07-27-2016, 01:34 AM   #18
    pllevine's Avatar
    Send pllevine:
    Thanks... I know it will...
    Phil Levine
    1998 202 Shabah
    Old 07-31-2016, 01:05 AM   #19
    My Model: Z202
    Send Firestone:
    Here is some pictures.
    John
    Old 07-31-2016, 02:44 AM   #20
    pllevine's Avatar
    Send pllevine:
    Thanks for the photos but mine isn't a Z202.... I just have the basic interior. No cool speaker nacelles, no vertical straps....
    Phil Levine
    1998 202 Shabah
    oil sump removal bustah Volvo Penta 3 11-14-2013 04:39 PM
    Wanted: port side camper panel BDQ Mariah Parts For Sale & Wanted 0 07-08-2012 10:53 PM
    remove interior side panels 96 talari z220 scott3558 Original Mariah Talk 7 08-27-2010 10:56 PM
    Need help With dashboard Removal niceguy167 Original Mariah Talk 2 06-08-2009 02:08 PM
    Side Panel removel jeffryb Original Mariah Talk 2 04-12-2009 12:55 PM
    There are 345 users
