Need help With dashboard Removal
Old 06-08-2009, 06:12 AM   #1
niceguy167 is currently offline
Send niceguy167:
Default Need help With dashboard Removal
Well its not excatly a dashboard but its right under it. I cannot for the life figure out how to remove it. I am thinking its removed by lifting up and releasing it from some hooks of some sort. But it wont budge and i defintally dont want to break it. Its on a 1992 Mariah MX19 I will attach a pic. Thanks
Steven.
  • Old 06-08-2009, 01:37 PM   #2
    jeffryb is currently offline
    My Model: 1993 19ft 1900z 4.3lx alpha one
    Send jeffryb:
    Default Re: Need help With dashboard Removal
    Ihad mine out this fall to replace my carpet. You have to gain access to it from the front seat and there are screws in the corner's, top and bottom and there should be a wood block screwed to the floor and there was a screw there also. The screws are hard to find in the carpet but they are there and mine were very long. Any more help give a shout and good luck.
    Old 06-08-2009, 02:08 PM   #3
    Send jeffryb:
    OOP'S, I was wrong, if you are looking at it from the driver's seat, the right top corner that screw you have to get that out from the side panel. If you have SS seating take the driver's seat of the pedalstal and you have to reach your arm through the side panel to get too the top right screw. I'm pretty sure that's it I'll think some more about it. Good Luck!!
    Wanted: Dashboard Repair pblouin Mariah Parts For Sale & Wanted 5 12-25-2010 04:20 AM
    Paint removal?? stereoman405 Original Mariah Talk 9 05-06-2009 10:31 AM
    Dashboard light switch noons28 Original Mariah Talk 1 04-20-2009 09:44 PM
    Dashboard woe's blockp Original Mariah Talk 2 10-15-2008 03:13 PM
    There are 268 users
