Neutral adjustment issue
Old 06-23-2013, 09:00 PM   #1
Lewy is currently offline
My Model: 182
My Engine: 4.3L mercriuser
Send Lewy:
Default Neutral adjustment issue
When for example I go from forward gear to neutral and then into reverse say for a quick burst of reverse when mooring, when I then click the lever back in to neutral, reverse hasn't always disengaged. is this a problem I can adjust at the remote end or should it be done at the other end of the shifter cables?
thanks for your advice.
Lewy
  • Old 06-23-2013, 09:32 PM   #2
    Default Re: Neutral adjustment issue
    Adjusting the shift cable requires 2 people. Have a look at this explanation:
    Lewy (06-24-2013)
    Vibration in neutral yblockmike Mercury MerCruiser 1 03-31-2011 05:02 PM
    sticky neutral button on volvo penta tagsfirst Original Mariah Talk 4 08-21-2010 06:44 AM
    Throttle Cable Adjustment??? berk1402 Mercury MerCruiser 0 07-06-2010 03:51 AM
    Docking light adjustment? ckgreenman General Maintenance 10 07-10-2009 10:09 PM
    Carb Adjustment 1992 Mariah 4.3 Litre seapoo Original Mariah Talk 6 07-01-2009 09:38 PM
    There are 342 users
