Intake leak????
Old 03-04-2013, 08:46 PM   #11
njc15880 is currently offline
My Model: Z272 Shabah
Send njc15880:
Default Re: Intake leak????
That is extremely helpful. So that K&N flame arrestor/filter will fit in place of the stock flame arrestor?
  • Old 03-05-2013, 01:10 AM   #12
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Take off the plastic cover and the flame areastor attaches to the round throttle body with a simple hose clamp.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    njc15880 (03-05-2013)
    Old 03-05-2013, 01:42 AM   #13
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    I have the K&N model. It still whistles
    2000 Z302 Bow Rider
    Old 03-05-2013, 03:09 PM   #14
    That sound is normal. That is a big motor and it requires a lot of air (and fuel!). If you were to modify your pickup trucks air intake to a straight pipe and filter it would sound the same while operating under load. That whistle sound is air moving through the throttle body. I kinda like that sound...
    Old 03-05-2013, 03:13 PM   #15
    I forgot to mention why I used a pickup truck as a comparison: To meet emissions standards they have to operate under a certain decibel limit therefore they put the sound chambers on the factory plumbing. Without those chambers the motor can actually be heard breathing!
    Old 03-06-2013, 12:37 PM   #16
    My Model: Z280
    To be clear, my 7.4 MPI does not whistle at cruising speed...it only whistles on deceleration when coming off plane.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-02-2013, 07:44 PM   #17
    Send njc15880:
    So I am revisiting this problem. I installed the filter that you recommended and the whistling did not stop. I even ran the boat with nothing on the throttle body at all. I am running low on ideas. I have narrowed it down to the throttle body I am pretty sure. Im thinking that the air moving through it is creating turbulence and causing the whistle. Is there a throttle body spacer that would work to see if that may be causing the issue?
    Old 07-02-2013, 07:57 PM   #18
    Gallery Images: 36
    Send Oregondunes:
    Mine whistled the same way. It's air rushing Over and thru the throttle body. Normal. You could always run a straight hose to yur engine bay vent
    2000 Z302 Bow Rider
    Gas tank leak syc92868 Original Mariah Talk 36 07-16-2013 01:56 AM
    Oil Leak From Water Intake Slash9point5 Mercury MerCruiser 4 08-15-2011 02:28 PM
    where is fresh water intake on 6.2L? csterner Mercury MerCruiser 1 04-21-2011 12:40 AM
    v6 12 bolt intake to v6 8 bolt intake motor SCOTT Original Mariah Talk 3 07-21-2009 01:30 AM
    Intake full of sand/mud - overheat cleah Mercury MerCruiser 2 09-19-2008 01:33 PM
    There are 331 users
