Intake full of sand/mud - overheat
Old 09-08-2008, 01:57 AM   #1
cleah is currently offline
Send cleah:
Default Intake full of sand/mud - overheat
Hi,
Last Saturday, we hit a sand/mud bank and burried the prop. We pushed the boat off the bank, and 20 seconds after starting got the buzzer. the temp gauge read 200 F so we immediately shut down and got a tow home. The boat (1993, 2350Z) had run for several hours with no temperature problems before that, the temp not going over 150 F. It has just had a new intake pump impeller. Is there a simple way to solve this, such as sticking a garden hose on one of the cooling system hoses to blow the sand/mud back out the intake holes?
Regards
Clive
  • Old 09-16-2008, 09:05 AM   #2
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    I had the exact same thing happen to me a year or so ago. Fortunately it was covered by insurance (submerged object - or something like that).
    The mechanic had to take off the complete water cooling system to get rid of everything. Some was baked on as it was mud, we couldnt get a tow so had to slowly head home at less than 5 kts for about an hour.
    The pump impeller was replaced and other minor things done but all is good now. The guys here with a ton of more knowledge will be able to help you better with regards to back flushing or cleaning it out though. So hopefully someone will pipe in soon to help you. Check with your insurance company as to whether you are covered, it may save you a few $.
    Good luck.
    Old 09-19-2008, 01:33 PM   #3
    You might want to try a set of these
    They attach to your outdrive water intake, and hook up to a standard garden hose. Turn it on, start your boat up, and run it for about 5 minutes, that should clear it all out!
    Mariah Z2350 Merc 7.4 overheat cleah Mercury MerCruiser 8 09-05-2008 03:39 PM
    Full canvas bimini top Segmenta Sea Fox - Mariah Talk 1 08-09-2008 11:00 AM
    engine acting wierd at full throttle MariahMX20 Mercury MerCruiser 8 07-16-2008 12:10 PM
    Battery box full of water dudders General Maintenance 5 08-28-2007 12:35 PM
    There are 433 users
