v6 12 bolt intake to v6 8 bolt intake motor
Old 07-20-2009, 11:15 PM   #1
SCOTT is currently offline
My Model: 1995 182 mariah barchetta 4.3 lx alpha 1 gen II
Send SCOTT:
Default v6 12 bolt intake to v6 8 bolt intake motor
bought new mecrusier v6 engine to replace an old 1995 v6 engine. Will the electric fuel pump and v belts bolt onto the new 8 bolt intake motor . I was told to use the 1995 flywheel housing so it mounts correctly in boat am I heading in the right direction? I was told a new 1995 version v6 did not exist brand new, all rebuilds THANKS SCOTT
  • Old 07-20-2009, 11:21 PM   #2
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Default Re: v6 12 bolt intake to v6 8 bolt intake motor
    I'm sorry, Scott, but your post made little sense to me
    Sounds like you're asking if you can install a 12-bolt intake manifold on a block that takes an 8-bolt manifold? I'm no expert on these engines: But my guess would be no.
    Jim
    Old 07-21-2009, 12:42 AM   #3
    Send SCOTT:
    Smile Re: v6 12 bolt intake to v6 8 bolt intake motor
    sorry about that Im changing an old v6 block w/12bolt intake with a new v6 block w/8bolt intake wondering if all pieces would fit new block MISSED (MOTOR) AFTER 12 BOLT INTAKE
    Old 07-21-2009, 01:30 AM   #4
    SEMIJim's Avatar
    Send SEMIJim:
    Like I wrote earlier: If you're asking if you can put an intake manifold with a 12-bolt pattern on a block with an 8-bolt pattern: My guess would be no, you cannot.
    Jim
    Help with power sundeck/motor lid jasfiveo Original Mariah Talk 14 04-03-2010 11:05 PM
    Prop, motor, altitude? otisroy Prop Talk 6 07-07-2009 03:01 PM
    Intake full of sand/mud - overheat cleah Mercury MerCruiser 2 09-19-2008 01:33 PM
    building new motor arice Original Mariah Talk 2 07-11-2008 09:18 PM
    Mariah 2003 with 190 HP Motor Joe Lisuzzo Sea Fox - Mariah Talk 4 06-30-2008 07:11 PM
    There are 260 users
