Need to replace starter 7.4L
Old 06-17-2013, 03:08 PM   #1
erb5858 is currently offline
My Engine: 7.4l Bravo III
Send erb5858:
Default Need to replace starter 7.4L
Anyone replaced the starter on there 7.4L mercruiser? I have a 1996 24' talari with a 454. Its extremely tight, what needs to be removed to gain access to the starter?
  • Old 06-17-2013, 05:37 PM   #2
    Default Re: Need to replace starter 7.4L
    jgreen did replace the starter on his 7.4 a couple of years ago. He did comment that the exhaust has to be removed to access it. You could always send him a private message to see if he can provide any other hints.
    I can suggest also that this might be a good time to consider becoming a contributing member to the site so that you gain access to the necessary shop manuals. Here is a list of what is available.
    Old 07-02-2013, 07:38 PM   #3
    njc15880 is currently offline
    My Model: Z272 Shabah
    Send njc15880:
    I replaced my Starter on my 2000 Z272. It is quite painful. They are 9/16 bolts that hold the starter in place. I sat in the bilge and felt my way through it. The toughest part was holding the new starter and getting the bolts started.
    Oregondunes likes this.
    Exhaust Manifold Replace ColoradoDiablo Mercury MerCruiser 2 01-13-2012 07:20 PM
    replace the gastank??? phillycincykid Original Mariah Talk 3 12-12-2011 01:21 AM
    Rebuild or replace engine? csterner Original Mariah Talk 22 06-30-2011 01:46 AM
    need to replace console peddlerman2001 Introductions 0 08-06-2010 09:16 PM
    Need to Replace Trim DONNA Original Mariah Talk 1 07-01-2010 09:45 AM
    There are 254 users
