Won't start
Old 07-15-2012, 02:30 AM   #1
DItR is currently offline
My Model: MX19
Send DItR:
Default Won't start
Hey guys,
Have a '92 mx19, 4.3LX / V6 with Thunderbolt IV Ignition.
Haven't tried starting it in 3-4yrs. Finally tried this year. No go. It cranks, won't start. Getting fuel to the carb. No power to the ignition coil. Good battery, looked at all the wires I can see, nothing jumped out at me that looked wrong. Tested coil by turning key on & checking positive post. Nothing. Any suggestions?
John
  • Old 07-15-2012, 03:59 AM   #2
    Default Re: Won't start
    Yep. Read this sticky located here in the Maintenance & Repairs section.
    Old 07-15-2012, 10:40 PM   #3
    My Model: MX19
    Send DItR:
    Thanks Mikey, the sticky did help me to test the ignition switch, which is good btw, but didn't help me beyond that. My engine cranks over but is not getting any spark. The + post on the ignition coil is dead. ( actually, cranking it has 0.2 volts coming to it.) I have a Clymer book & it says, "if no voltage is noted on the ignition coil + post, then check the engine wiring harness, inst. panel wiring harness, battery cables and ignition switch for open or shorted circuits." It stops there & doesn't go any further.
    Have checked all of that & it all looks good to go. Obviously something is wrong but I can't find it. Any more help from you or anyone would be greatly appreciated.
    Thanks again.
    John
    Won't start??? Smanderville General Maintenance 3 05-07-2012 12:58 AM
    no start wcso909 Mercury MerCruiser 3 06-06-2011 05:32 AM
    Clicks but won't start! newbie Original Mariah Talk 4 06-02-2011 09:29 PM
    Hot start Hyperryd Mercury MerCruiser 2 06-25-2010 02:41 AM
    Z275 Won't start chadcane Original Mariah Talk 0 11-11-2009 04:43 PM
    There are 345 users
