Won't start???
General Maintenance
Old 05-06-2012, 04:08 PM   #1
Smanderville is currently offline
My Year: 2009
My Model: RX181
Send Smanderville:
Default Won't start???
My battery is fine and there is power to everything, but when I put the key in and flip the switch to run....there is no tone, and nothing happens on the gauges.
Is there a blown fuse or breaker for the ignition or starter? Is there jut a disconnected wire? Or does it sound like something needs to be replaced?
  • Old 05-06-2012, 04:59 PM   #2
    Default Re: Won't start???
    Welcome to MOC
    Need more info. What boat , what year , what power package , etc.
    Does it have a safety kill switch?
    Larry
    Old 05-07-2012, 12:53 AM   #3
    My Year: 2009
    My Model: RX181
    Send Smanderville:
    2009 Mariah bowrider mercruiser etc ...
    Yes I believe there is a safety kill but need to double check....it's just weird, that there is power to everything else but the ignition and gauges...I feel like something might just be disconnected.
    Old 05-07-2012, 12:58 AM   #4
    Even with the safety kill switch it should turn over. I would check to see that you actually hooked up the small wires (ignition/accessory wiring etc) to both of the battery terminals. Sometimes they can be forgotten if they hang down behind the battery box etc.
    No Start Question stevorat Sea Fox - Mariah Talk 10 05-09-2015 02:34 PM
    no start wcso909 Mercury MerCruiser 3 06-06-2011 05:32 AM
    Clicks but won't start! newbie Original Mariah Talk 4 06-02-2011 09:29 PM
    Hot start Hyperryd Mercury MerCruiser 2 06-25-2010 02:41 AM
    Boat won't start kgoo Original Mariah Talk 21 08-07-2009 06:25 PM
    There are 251 users
