2350Z Power steering
Old 06-13-2011, 03:50 AM   #1
Tawakoni Paul is currently offline
My Model: 2350Z
My Engine: 7.4L Bravo 1
Send Tawakoni Paul:
Default 2350Z Power steering
I am a new owner of a 1993 2350Z and I was able to have a low pressure return hose made up by a local Auto Parts store which saved a ton of money. The original owner just added power steering fluid. One more problem solved.
  • Old 06-20-2011, 09:30 PM   #2
    theeasynine's Avatar
    My Model: z240 Talari
    Send theeasynine:
    Default Re: 2350Z Power steering
    Always good to fix a problem instead of being lazy. Got any pics?
    Patrick
    Old 06-20-2011, 09:47 PM   #3
    My Model: 2350Z
    Send Tawakoni Paul:
    No, I haven't taken any pictures. Thanks for noting the success.
    Old 06-20-2011, 10:10 PM   #4
    Send theeasynine:
    Any other projects you got to work on?
    Patrick
    Old 06-20-2011, 10:46 PM   #5
    My Model: 2350Z
    Send Tawakoni Paul:
    As a matter of fact YES! I am trying to find out what the water pickup is for that goes through the hull on the port side just in the front of the engine. There is water getting in the boat from somewhere that I haven't found yet. I have checked the 3 bellows but haven't seen a hole. No water is getting in when the engine in running with water comming from the hose, so I assume I don't have an open petcock. There is not much room to see things with a 454 engine. There are several more little things to take care, but the good news is it runs like a scared rabbit-about 54 MPH.
    Old 06-21-2011, 12:12 AM   #6
    Send theeasynine:
    That 454 is a beast. I love how Mariahs didn't underpower their boats by any means.
    On mine after I pull out the engine compartments and flip forward the rear seat there's a good amount of room to work.
    Patrick
    Old 06-21-2011, 12:43 AM   #7
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    That water pickup on the port side is probably for your water pump. That is how mine is set up as well. Mine does not draw raw water in for cooling thru the outdrive. It pulls water thru that fitting instead. Hope that helps.
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 06-21-2011, 03:30 AM   #8
    My Model: 2350Z
    Send Tawakoni Paul:
    Chris,
    Thanks for the input. That makes a lot of sense, however I know that my Bravo outdrive also pickes up water from the outdrive as that is where I attach the ears for the hose. I haven't followed the hose to the pump but it looks like that is where it goes. It is interesting that there is a ball valve at the spot that the water pick up comes through the hull.
    Patrick, I also have more room to work when I remove the engine compartment sides and move the rear seat forward but it is still very tight getting under the exaust manifolds to check things out.
    Old 06-21-2011, 03:14 PM   #9
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    To me from what you have said it sounds exactly like a bellows leak I had a small on onthe big bellows and took me for ever to find the darn thing changed them all out while I was in there ounce of prevention you know lol
    darkcalling
    Z 278 Limited
    Old 06-24-2011, 01:42 AM   #10
    voodoo's Avatar
    voodoo is currently offline
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    My 94 Davanti has a water pick up there. It appears to be for the swim platform shower.
    I
    power steering cable bethk Original Mariah Talk 3 10-31-2021 09:36 PM
    power steering freeman81 Boating 101 7 02-04-2011 06:53 PM
    power steering question depman160 Boating 101 2 11-12-2009 08:42 PM
    2350 Z power steering cleah Mercury MerCruiser 2 09-09-2008 02:17 AM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    There are 292 users
