power steering
Boating 101
Old 01-31-2011, 09:59 PM   #1
freeman81's Avatar
freeman81 is currently offline
My Model: Diablo Bowrider
My Engine: 4.6L alpha 1
Send freeman81:
Default power steering
I have a 93 mariah diablo bowrider with the 4.3L alpha 1 moter. The issue I have is with the power steering... I have replaced the pump and it has fluid and is pumping but the wheel is very stiff and hard to turn in and out of the water??? Any suggestions please help!!
  • Old 02-02-2011, 06:15 AM   #2
    scubydo is currently offline
    My Model: 200
    Send scubydo:
    Default Re: power steering
    My 1996 200 Shabah has the exact same issue. Very hard to turn. I'm not sure of the cause, but plan to dig into it in the spring.
    Thank you scubydo for this useful post!
    freeman81 (02-03-2011)
    Old 02-03-2011, 03:57 AM   #3
    simpleaz's Avatar
    simpleaz is currently offline
    Send simpleaz:
    Just a guess but probably the steering cable worn. Search for some thoughts. Binding somewhere?
    1996 Mariah Shabah 200 5.7L
    Thank you simpleaz for this useful post!
    Old 02-03-2011, 04:51 AM   #4
    jgreen's Avatar
    jgreen is currently offline
    Gallery Images: 2
    Send jgreen:
    My 240 had very stiff steering too. It needed a new Control Valve.
    Jay
    Thank you jgreen for this useful post!
    Old 02-03-2011, 10:54 PM   #5
    freeman81's Avatar
    Send freeman81:
    well maybe one of those responces are the answer I just hope that its not to expensive like repairing the rack and pinion system or anything like that...
    Old 02-04-2011, 12:12 AM   #6
    jgreen's Avatar
    Gallery Images: 2
    Send jgreen:
    I don't remember what mine cost exactly, but with a big block there was a lot of work getting to it. I think the part was only a couple hundred. With your smaller engine, you may be able to get to it a lot easier. Of course, you'll need a good diagnosis of the problem first. Good luck.
    Jay
    freeman81 (02-04-2011)
    Old 02-04-2011, 01:25 AM   #7
    al levy is currently offline
    My Model: 272 shabah
    My Engine: 7.4 bravo 111
    Send al levy:
    if the steering wheel stiff when the motor is off? can you turn the outdrive by hand. if not most likely the cable is the problem. You can disconnect by the transom and then turn the wheel. there is a sleeve or cylinder that does have a grease fitting but it really sounds like a cable. not too big of a job usually.
    Thank you al levy for this useful post!
    Old 02-04-2011, 06:53 PM   #8
    freeman81's Avatar
    Send freeman81:
    yeah its stiff even with the motor off. I cant turn the outdrive by hand so hopefully it is just a cable...
    Power Steering Pulley Replacement DINKS Life Mercury MerCruiser 4 06-15-2013 02:01 AM
    power steering question depman160 Boating 101 2 11-12-2009 08:42 PM
    2350 Z power steering cleah Mercury MerCruiser 2 09-09-2008 02:17 AM
    changing power steering pump 01DiabloMissouri Original Mariah Talk 2 07-09-2008 01:51 PM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    There are 337 users
