2350 Z power steering
Old 09-08-2008, 01:59 AM   #1
cleah is currently offline
Send cleah:
Default 2350 Z power steering
Hi,
I took my recently purchase 1993, 2350 Z on the water on Saturday. There was no power steering fluid in the reservoir, so we filled it up. It drained out into the sump with use and the steering was very heavy turning right, though left remained fine. If you have had the same problem, please let me know how you solved it.
Clive
  • Old 09-08-2008, 02:36 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Likely a bad seal on the pump. Or a leaky hose. Fill it up, run it and observe around the pulley shaft for leaks.
    My Mariah
    Old 09-09-2008, 02:17 AM   #3
    Send cleah:
    Default 2350 Z power steering leak
    Will do.
    Clive
    Power Steering Pulley Replacement DINKS Life Mercury MerCruiser 4 06-15-2013 02:01 AM
    changing power steering pump 01DiabloMissouri Original Mariah Talk 2 07-09-2008 01:51 PM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    mariah 2350 cz in good old germany mariah2350cz Introductions 1 11-01-2007 11:31 PM
    mariah 2350 cz mariah2350cz Original Mariah Talk 0 11-01-2007 09:23 PM
    There are 279 users
