Pulling engine
Old 06-20-2011, 01:40 PM   #1
drcfy is currently offline
My Model: 200 Talari
My Engine: 5.0 LX V8 Alpha one
Send drcfy:
Default Pulling engine
I am in the process of pulling the engine on my 1995 Talari 200. My guestion is: Do I have to remove the outdrive unit or can I leave it in place and be able to remove and replace the engine?
  • Old 06-20-2011, 03:05 PM   #2
    rajjneef's Avatar
    rajjneef is currently offline
    My Year: 97'
    My Model: Z242 Shabah
    My Engine: 350 efi Bravo III
    Gallery Images: 3
    Send rajjneef:
    Default Re: Pulling engine
    You have to remove the outdrive. You will also need an alignment tool after install.
    Thank you rajjneef for this useful post!
    drcfy (06-20-2011)
    Old 06-20-2011, 03:22 PM   #3
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Rajj be 100% correct on that it has to come off and you will need the alignment tool to reinstall when your done.
    Thank you darkcalling for this useful post!
    drcfy (06-20-2011)
    Old 06-26-2011, 02:17 PM   #4
    Send drcfy:
    Okay, everything went great! The out-drive came out with no problems. Built an "A" frame after seeing the picture of Chris pulling his engine in another thread and with the manuals through Mariah owners club and good advice from members, the engine is out. I still cannot believe how easy and enjoyable it has been so far. Thank you.
    I am having to replace the engine and the port manifold due to the extreme freeze we had here in Texas this last winter. And because I didn't think about putting some heat in the engine compartment during those cold days.
    My next step is to get the engine in my garage to work on it. I am wondering if a regular engine stand will work? Will I need to remove the housing at the rear of the engine or do I modify the engine stand somehow to connect them?
    Pulling the motor super10lbz Mercury MerCruiser 7 04-27-2011 07:21 PM
    There are 284 users
