warning alarm only beeps twice.
Old 04-23-2011, 01:15 AM   #1
Brad's Avatar
Brad is currently offline
My Model: Z202 Shabah
My Engine: 5.0 EFI Alpha 1
Send Brad:
Default warning alarm only beeps twice.
Hi guys, I am the proud new owner of a 2000 Z202. Merc 5.0 EFI. I notice when I key on, the alarm only sounds twice. I have tried to duplicate a low oil pressure alarm by unplugging the oil sensor with engine running. Gauge will read zero but no alarm. Same with jumping the drive level sensor. Any advice would be super. Thanks Brad.
  • Old 04-23-2011, 10:39 PM   #2
    Default Re: warning alarm only beeps twice.
    chances are it's not the oil pressure. do a quick search on here for "Alarm" and you'll find all the info you need. A lot of us have experienced an issue with one of the 3 sensors going bad!
    Old 04-24-2011, 12:30 AM   #3
    Brad's Avatar
    Send Brad:
    Thanks for the reply, but I dont think my problem is like the others i found when I serched "alarm". My alarm will not work. should beep untill engine starts. Mine will only beep twice then stops, even when engine not running. I short the tan/blue wire to groung still no alarm. Im wondering if the ECM controls the alarm signal.
    Old 04-24-2011, 12:44 AM   #4
    MariahMan's Avatar
    Status: Admin Guy
    My Model: 252 Shabah
    Gallery Images: 211
    Send MariahMan:
    Brad,
    On our 2001 252 Shabah w/ the Volvo 5.7, it only beeps twice and cycles the fuel pump when you turn the key to run. After 2 beeps, you can hear the fuel pump running and then of course you can turn to ignition and release when the boat starts. Again, just two beeps. Perhaps it's normal on the newer boats? You may not have a problem after all.
    Good luck.
    -Ryan
    ThunderShark Web Solutions
    Old 04-24-2011, 03:07 AM   #5
    Brad's Avatar
    Send Brad:
    Thanks Ryan. that makes me feel better. Iwill keep a close eye on the gauges untill I know the system is working properly.
    Brad.
    SX19 won't start and high pitch warning(?) noise 06_19SX Sea Fox - Mariah Talk 13 08-26-2023 01:26 AM
    Alarm Shabah 198SE Original Mariah Talk 14 08-31-2010 02:38 AM
    Warning Alarm Beeping Every 4 seconds ShabahZ280 Mercury MerCruiser 8 11-05-2008 03:35 PM
    Sensor Warning On Trim? 2 OWNER MARIAH Original Mariah Talk 4 06-10-2008 03:33 AM
    7.4L MPI Engine Warning Alarm ShabahZ280 Mercury MerCruiser 13 02-09-2008 07:39 PM
    There are 253 users
