Sensor Warning On Trim?
Old 06-09-2008, 03:02 AM   #1
2 OWNER MARIAH is currently offline
My Model: 2001 222 Shabah, Phoenix Yellow w. Small Indy Style Graphics, 1999 Z280 MCC
Send 2 OWNER MARIAH:
Default Sensor Warning On Trim?
Was out on our 99 Z280 today on a slow speed cruise and decided to get it into a 20 to 30 mph cruising speed. When we reached our 20 to 30 mph I heard a warning beep that kept beeping until I shut the engine down and restarted it. Did this over again about 3-4 times and kept doing the same thing.
When I had told this to one of the boaters at the Marina he said it might be low on trim oil and before it planes out it might run the oil in the low position. Never checked it yet but was wondering if anyone has had this problem and if there are low oil sensors on the trim or the bennet tabs with warning alarms.
2 OWNER MARIAH
  • Old 06-09-2008, 02:49 PM   #2
    There's a sensor on the lower unit trim pump. Check your fluid level. The pump (at least on mine) is on the port side in the rear. It has a yellow cap on a reservoir. From what I hear, the sensors are a common problem on the Mercruiser warning system. One of mine isn't functioning properly right now either.
    The trim tabs don't have anything to do with it. They're completely seperate, and have no sensors or alarms to go off. They just stop working if something goes wrong!
    Old 06-09-2008, 03:03 PM   #3
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Also check your lower unit drive oil (reservoir is on the starboard side, front of the engine on mine). It could be low and setting the alarm depending on the boat's degree of tilt while under way.
    I'm assuming you didn't have a high temperature situation, right?
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 06-09-2008, 04:56 PM   #4
    Mariah_in_636 is currently offline
    My Model: 1999 Shabah 252 with 7.4MPI and Bravo III
    Gallery Images: 4
    Send Mariah_in_636:
    I would bet dollars to donughts that the drive oil is low. I just had this same type situation about 3 weeeks ago. Very easy to check. Theres a sticker right on the side of the resivoir. Mine is located on the port side near the front in a white resivoir.
    Good luck.
    Old 06-10-2008, 03:33 AM   #5
    Thanks for your replies, will check oil level. Hope it is that simple.
    Prop Trim Button PouredOut General Maintenance 9 07-03-2008 04:57 AM
    Trim trouble shilo Sea Fox - Mariah Talk 5 02-20-2008 02:24 PM
    7.4L MPI Engine Warning Alarm ShabahZ280 Mercury MerCruiser 13 02-09-2008 07:39 PM
    Air Temp Sensor rjobe Original Mariah Talk 5 09-17-2007 02:45 AM
    trim trouble aquaknot Original Mariah Talk 5 08-13-2007 12:17 PM
    There are 307 users
