Alarm
Old 08-26-2010, 11:28 PM   #1
Shabah 198SE's Avatar
Shabah 198SE is currently offline
My Model: Shabah 198SE
My Engine: 5.7L Alpha
Send Shabah 198SE:
Default Alarm
Can the brain shattering alarm that sounds when the key is turned on be eliminated on my 1997 198SE Shabah (Mercruiser 5.7 Litre - 2 Barrel)?
Shabah 198SE
  • Old 08-26-2010, 11:33 PM   #2
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Default Re: Alarm
    If you "pump" the accelerator two-three times and get her started right up, it shouldn't sound at all, or, at least, not for very long. Ours has a 10-15 second delay, and I rarely hear it come on. If it does: I just turn the key off so I get another 10-15 seconds of grace .
    Jim
    Thank you SEMIJim for this useful post!
    Dutch180SE (08-28-2010)
    Old 08-27-2010, 11:16 AM   #3
    Send Shabah 198SE:
    Default Re: Alarm
    Jim
    SEMIJim,
    Thanks for your reply. I will give that a try.
    I was just checking things over yesterday for today's launch and I turned the key on. It scared the crap out of me. The shifter is in the forword position as it was when I trailered it home. Maybe it doesn't like that.
    Is that a Mariah alarm or a Mercury alarm?
    Shabah 198SE
    Old 08-27-2010, 11:48 AM   #4
    Default Re: Alarm
    That's a Mercruiser alarm. Yes, it is annoying, but it's there for a reason, to warn you of three different things, low oil pressure, low gear lube, and high engine temperature. If your alarm is sounding, after the initial start up, it's one of those 3 things, and I recommend getting the engine checked out by a Mercruiser service facility. When I first bought mine, I kept wondering why every other boat had the initial start up alarm and mine didn't. Did some snooping around behind the dash and found the previous owner had disconnected the alarm. Not cool... When I reconnected it, the alarm went off consistently until I had the engine fixed... Turns out it was the gear lube reservoir sensor, which seems to be a common issue. Replaced the reservoir and sensor, and haven't had any troubles since!
    Old 08-27-2010, 11:53 AM   #5
    SEMIJim's Avatar
    Send SEMIJim:
    Default Re: Alarm
    I don't know as one would call it a "Mariah alarm" or a "Mercury alarm." The sensors are all put there by MerCruiser, and the alarm module and wiring were put there by Mariah. So I guess it's a "Mariah/MerCruiser alarm"
    Three things are monitored: Outdrive lube level, engine temperature and oil pressure. It's the latter that causes the alarm to sound when you first start the engine--until the oil pressure comes up.
    The position of the shifter is inconsequential.
    Be glad your alarm is working. It may save you some expensive damage, some day. Original owner of our boat, I assume, had disconnected ours.
    Jim
    Old 08-27-2010, 09:39 PM   #6
    Send Shabah 198SE:
    Default Re: Alarm
    ShabahZ250,
    The alarm does not sound when the engine is running. It will sound if it stalls.
    Shabah 198SE
    Old 08-27-2010, 09:43 PM   #7
    Send Shabah 198SE:
    Default Re: Alarm
    Jim
    SEMIJim,
    Now that I know it is there, it is not as bad. It is also better with the top down.
    Shabah 198SE
    Old 08-28-2010, 12:27 AM   #8
    scubydo is currently offline
    My Model: 200
    Send scubydo:
    Default Re: Alarm
    I disabled mine, becasue they had the radio wired up to the ignition, and the only way to listen to the radio with the engine turned off was to listen to the alarm. I think I'm going to reconnect it and use one of the accessory switched for the radio power. My alarm doesn't have the 15 second delay, it comes on right with the key. Is there anyway to add a delay to it???? I would much rather have it hooked up, but can't stand the noise it makes... I would prefer some flashing lights on the dash to alert me of a problem.
    Old 08-28-2010, 02:25 AM   #9
    SEMIJim's Avatar
    Send SEMIJim:
    Default Re: Alarm
    You mean you have the ignition switch in the "run" position, w/o the engine running, to listen to the radio? That's not a good thing to do. With some systems, you can toast your ignition by doing that.
    Our radio runs with the switch in either the "run" or "acc" position--just as it is with an automobile.
    Jim
    Old 08-28-2010, 02:40 AM   #10
    Send Shabah 198SE:
    Default Re: Alarm
    scubydo,
    Our radio is hooked into the accessory switch that is live when the ignition key is in the accessory and/or on position. This would solve your problem and also eliminate the possibility of accidentally leaving your radio on and draining your battery.
    LIke you, my alarm sounds as soon as the key is turned to the on position. I don't mind having the alarm, but I would like to quiet it down a bit. Maybe I can put it in a box.
    Shabah 198SE
    Intermittent Alarm oneilld Boating 101 9 08-29-2010 01:48 PM
    Alarm florida22 General Maintenance 2 06-20-2010 01:05 PM
    why is my alarm going off ? Wurknman Original Mariah Talk 6 06-19-2009 08:44 PM
    Alarm? jmo Mercury MerCruiser 3 09-09-2008 02:09 AM
    alarm Mark Original Mariah Talk 10 11-26-2007 05:49 PM
    There are 344 users
