Trailer Vibration - Only at 35mph?
Trailering and Tow Vehicles
Old 09-10-2010, 08:48 PM   #1
Slash9point5's Avatar
My Model: Barchetta 182
Send Slash9point5:
Default Trailer Vibration - Only at 35mph?
Hello Fellow Mariah Owners Club Members,
I have an interesting trailer symptom I was hoping to find an answer for:
When I am towing our 1995 Mariah Barchetta 182 on our 1994 Chariot Trailer, we get a noticeable vibration at 35 mph and only a 35 mph. At speeds faster and slower that 35 mph, there is no vibration. I would describe the vibration as a side-to-side shimmy.
Background:
1) This vibration started to occur after we had brakes and a new axle put on our trailer.
2) The first trip after the upgrades the drive side tire ground off the outside tread edge of the tire so bad that the tire eventually split en route to the trailer company (to be fair the tires from the PO were very old and weather checked so that was most likely the reason)
3) Due to the type of axle that was installed, a longer shank was required to lower the back connection of the leaf spring to make it so the tire had adequate clearance from the fender.
4) I have the correct ball mount on our tow vehicle to make sure the trailer is level, but I have tried a couple other ball mount heights, and the symptom still exists.
If you have any questions, or possible solutions, please let me know.
Thank you for your time and have a great day,
Kris
  • Old 09-11-2010, 10:35 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: Trailer Vibration - Only at 35mph?
    Could it be something as simple as tires not properly balanced?
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 09-12-2010, 06:59 PM   #3
    Send Slash9point5:
    From the posts I have read on other forums, that could definitely be a potential source...but I had the tires balances 1 month ago when I got new tires (Carisle Radials). If I can't come up with anything else, I will probably take it in and have them recheck the balance.
    Old 09-13-2010, 10:09 PM   #4
    Shabah 198SE's Avatar
    Shabah 198SE is currently offline
    My Model: Shabah 198SE
    My Engine: 5.7L Alpha
    Send Shabah 198SE:
    Slash9point5,
    I would be concerned about the tire wearing on one edge. Are the new tires showing this same kind of wear pattern? If yes, you may have a loose, or bad, wheel bearing or the spindle/axle on that side may be bent or not correctly installed. This wear pattern would indicate that you had too much (+ or -) camber or toe in (or out) on that wheel.
    If your trailer has brakes, an out of round brake drum may also cause a vibration.
    Good Luck
    Shabah 198SE
    Old 05-13-2011, 03:13 PM   #5
    dominick is currently offline
    Send dominick:
    Bad wheel bearing?
    Old 05-13-2011, 05:15 PM   #6
    Send Slash9point5:
    I believe the issue was the trailer tires being out of balance (even though they balanced them when they replaced the tires).
    Just before I put the boat away, I had them rebalanced and I did not feel the vibration on the drive back home. I will be able to tell for sure after a few trips this year, but if I don't repost that was the issue.
    I imagine they were improperly balanced because I wanted to switch out the spare tire time with one of the other rims, and of course they forgot. So, I bet they didn't check the balance when they switched them.
    As for the tire wearing only on one side. After the tires were replaced, there was no further evidence of this. We trailered to boat up North ~200 miles each way. So I am going to chalk it up to really old trailer tires, and continue to monitor the situation.
    Used trailer - what to look for ..? 180diablo Trailering and Tow Vehicles 9 07-15-2011 04:27 AM
    Looking for a trailer 22empire Other For Sale 6 04-18-2009 02:35 PM
    My trailer fix Mark Original Mariah Talk 0 09-09-2008 11:39 AM
    Vibration from Outdrive? dudders Mercury MerCruiser 10 01-13-2008 04:09 AM
    Trailer Loading Aid WetWilly Trailering and Tow Vehicles 0 10-17-2007 04:30 PM
    There are 251 users
