Tempurature sensor question
Old 08-03-2010, 02:16 PM   #1
ggrims is currently offline
My Model: Shabah
My Engine: 350 magnum
Gallery Images: 2
Send ggrims:
Default Tempurature sensor question
Hi, I didnt want to hijack the other thread about the sensor wire so here is a new one. I replaced the thermostat housing on my 92 350 mag. The two holes for the two tempurature sending units are not in the same place. The newer style housings have the port side sensor toward the back of the housing. It ont fit now as it hits the intake manifold. What can I do to make sure both of these sending units work. Is there a sending unit that both of these wires could hook to, Also I see a plg in the intake maifold to the the side of the housing, can this be used to install the sensor. Thanks
    Temperature sensor ?? lowerthanu Mercury MerCruiser 0 05-25-2010 04:21 AM
    Mercruiser 454 with Bravo 1 - trim sensor cleah Mercury MerCruiser 8 10-01-2008 01:33 PM
    Sensor Warning On Trim? 2 OWNER MARIAH Original Mariah Talk 4 06-10-2008 03:33 AM
    Air Temp Sensor rjobe Original Mariah Talk 5 09-17-2007 02:45 AM
    There are 374 users
