Mercruiser 7.4 idle issues
Old 05-31-2010, 02:15 AM   #1
lowerthanu is currently offline
My Model: Z240
My Engine: 7.4 Bravo I
Send lowerthanu:
Default Mercruiser 7.4 idle issues
Hey guys,
I have a 92 Mariah Z240 with the carbureted 454 in it that bought last year. I took it out once and it ran fine with no issues.
This spring I did a tune up on it including plugs, wires, cap, + rotor. I started it on the hose 2 times and it ran just fine. I took it out this weekend to the lake, and it fired up with no issues, but after 10 minutes of running, it started to have an idle problem. Any time I would bring it down to idle, it would start to run rough and smoke black out of the exhaust. Basically under 1200 RPM's in or out of gear it would do this. If I did not work the throttle, it would die and be very hard to restart. At anything over idle, it ran great with no issues.
Any ideas what the fix may be? Thanks again.
  • Old 05-31-2010, 02:45 AM   #2
    FreeSpirit 2777 is currently offline
    My Model: Z255 Shabah
    My Engine: 7.4l Bravo III
    Send FreeSpirit 2777:
    Default Re: Mercruiser 7.4 idle issues
    The carter afb carbs had very small idle air passages and some fuels will clogged them up if it sits for some time..if this is the case you will need to remove carb and clean passages and reinstall.
    Old 06-20-2010, 03:07 PM   #3
    tclark is currently offline
    My Model: 1997 Shabah Z210
    My Engine: 5.7L Bravo III
    Send tclark:
    I have a 97 Mariah Z210 and it performs similarto yours. Starts and runs great on land on the hose and then once on the water starts right up but after 10 min or so of low speed or at idle starts to run rough or stalls. Very difficult to start after that. Also sometimes when you attempt to restart, it seems there is no power. You turn the key and nothing happens. This seems to go on for several minutes. Any suggestions.
    5.7 inboard issues chriskeller82 Boating 101 4 07-24-2010 10:09 PM
    98 242 Z Nav light issues DRTutt Original Mariah Talk 2 05-10-2010 05:39 PM
    fuel issues murphysocc Mercury MerCruiser 9 09-14-2009 09:59 PM
    Prop Issues donb. Prop Talk 5 08-12-2009 09:23 PM
    Very rough idle dleeg5199 Original Mariah Talk 1 07-20-2009 02:41 PM
    There are 437 users
